跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
958 个问题 查看全部
Can I fix a slightly separated case?
I dropped my iPod classic 160GB about a foot from the ground. The front and back cases are now slightly misaligned by about .5 mm. I can press the case together with my fingers, but it springs back when I release the pressure.
Is this hard to repair? (I looked at the dissassembly guide, but they didn't have any advice on how to make certain that the case was put back together properly, other than saying to follow the guide backwards.)
Also, would it make any major difference in the functioning of my iPod? I think it works OK now, but would it be more vunerable to dust or other contamination?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
iPhone 电池维修工具包
只要 $29.99
Buy Now
iPhone 电池维修工具包
只要 $29.99
Buy Now
1个答案
已选择的解决方案
mintnowplease, sound like one of the tabs on the back case has either bend inwards or broke off. You can try and take the case apart, check the tab and see if you can bend it up. Otherwise I would just replace the back. By not fixing it, you are running risk of it coming either totally apart, which could rip the zif cable. Of course contamination with dust, dirt etc is always a possibility too.
这个答案有帮助吗?
按维修分数 2
评论:
Thanks - I have a replacement/repair plan from Target (where I bought the iPod). I didn't know it was a serious problem. Now I know what to do.
添加一条评论
添加你的答案
mintnowplease 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 343
