iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2993 个问题 查看全部
Waterdamaged iPhone not recognized by iTunes when trying to restore
Hi,
About a week ago, I was at soccer practice when it started to rain hard. My iPhone was in my bag and the water got through my bag, wetting the iPhone. When I got home, the screen was still on, so I turned it off and used a dust cleaner to get some water out of most of the holes. After that, I put it in a bowl of dry rice for about 48 hours. When I took it out, it had started to work again, but the home button didn't function properly. Then, about 2 days ago, the screen just turned black. It only worked when I had it plugged in, charging, and even then, there was no 3G connection or Wifi available. This kept on going, if it was plugged out, there was only a black screen. I then tried to restore it, but when I clicked restore, after 30 seconds, iTunes said there was an error 2001, or 21. Now my iPhone's screen is black, but if I click the power button, the apple logo starts up, then turning to the "Connect to iTunes" Screen. Is there any way to fix this?
Thank in advance!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
Nei Joanidhi, for the errors check on here. Since you are dealing with water damage, and your faults got progressively worse, I recommend that you clean your phone. Use these guides to disassemble your phone, and follow this guide for the cleaning process. It was written for a 3G but all the points apply to your phone as well. After you cleaned it properly, replace the battery and re-evaluate for further, if any, damage. Since it does sound like corrosion damage, I would also suggest that you do not continue to try to start your phone. You may accidentally cause more problems. Hope this helps, good luck.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
Nei Joanidhi 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 5
总计 1,261
