跳转到主内容
MacBook Pro带有15寸屏幕的型号
8234 个问题 查看全部
问题已关闭
What part of the screen is causing this problem?
My son brought my old laptop to his cousin's house (not in a laptop bag mind you). He doesn't remember dropping it but now the screen is doing this:
http://flic.kr/p/d2WLyd
Opening and closing the screen doesn't change the pattern (trying to rule out a loose wire).
Thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
This issue is a damaged LCD display. Below is the guide to replacing the LCD display (Assuming your Macbook Pro is a Pre-Unibody model judging by the picture)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement
Hope this helps,
这个答案有帮助吗?
得分 1
1条评论:
Thanks, new LCD on order!
完成的
添加一条评论
最有帮助的答案
I dont think that a loose wire would have that effect. That seems to be a cracked screen.
这个答案有帮助吗?
得分 1
3条评论:
The LCD looks perfectly normal when off. Cracked from the inside?
完成的
One of the layers of the lcd screen is most likely cracked. I just searched MBP cracked screen and the images returned look a lot like the issue you have, eg.
http://www.daytonanetworks.com/wp-conten...
完成的
If you want to make sure that the issue is not GPU, cables or connections related, hook it to an external screen.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 379
