跳转到主内容
iMac G4 17" 1.25 GHz Model M9168LLA PowerMac 6,1 introduced in 2003.
20 个问题 查看全部
Tried open firmware password reset shown here & doesn't work, ideas?
The answer here was under "How do I reset the open firmware password on my Mac?"
I think I've done exactly as the instructions said, but maybe I missed a step?
I have pulled the easy to access RAM from the base of the iMac and zapped the PRAM, but can't get past the lock and arrow icons. The Command-Option-PR PRAM set doesn't do anything - no chimes as is usual. Clicking the Option key thereafter just takes me back to the dreaded lock and arrow. I mistakenly set my startup to NetBoot and now can't get it back to restart from the hard drive... help! The CD drive isn't working correctly either so holding down the D key doesn't get me anywhere either.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Do you mean the RAM on the motherboard rather than the RAM I removed? Removing the RAM as I did above doesn't give me the chimes as I said, or flashes on the mouse light or any other indicator that it has done anything.
The problem started when I was trying to install new system software and mistakenly hit the "Network Startup" instead of the disk icon. Would getting a Netboot from somewhere solve the problem? Or at least let me boot up this computer? We bought it used and while I have a call in to the original owner I haven't been able to get the password from him.
完成的
I pulled out the RAM on the motherboard just now and tried to reboot with none in and it gave me a solid booop, but no chimes. Then I put the RAM back in, held down the command-option-p-r keys and it chimed once then went right to the netboot symbol, not past it. Turned it off, then held down the option key and turned it back on. Same lock and arrow symbol.
完成的
添加一条评论
1个答案
已选择的解决方案
1) Add or remove the number of DIMMs to change the total amount of RAM in the computer.
2) Then, the PRAM must be reset 3 times. (Command + Option + P + R) by continually holding the keys down until you hear the "bong" 3x
3) Allow normal boot process to proceed.
If this answer was helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
3条评论:
If you only have one RAM chip you have to buy a second one, the machine will not boot without RAM and not changing the RAM (simply removing or moving it around) won't rest the firmware.
完成的
Okay. I don't have another 512 chip. Would a 256 work?
完成的
yes the EFI just needs to detect the change.
完成的
添加一条评论
添加你的答案
bookgrrl 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 10
总计 2,250
