跳转到主内容
非一体化电脑称之为台式机。
2123 个问题 查看全部
What's wrong with my front USB ports? See description.
I use a USB headphone and usually connect it to the front USB ports.Off late,I'm having trouble with the ports.Whenever I connect my headphone,even the slightest movement disconnects the headphone from the computer.And sometimes,I also get a notification bubble saying "USD device not recognized".
I'm certain that something is wrong with the ports and not the headphone because I experience the same problems when I connect my external HDD.Both my external HDD and headphone work fine when I connect it with the USB ports at the back of my CPU.So,what is the problem?How do I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I assume you want to keep your front USB ports and not add more to the back. Here is a link to some front mounted USB ports--one of these should solve your problem. It would appear the port on the front of your computer is worn out. Good luck.
http://www.newegg.com/Product/ProductLis...
这个答案有帮助吗?
得分 3
添加一条评论
This can be caused by a lot of things, From shorts in the device's you attach and the ports themselves, Too incompatibility between USB ver 1-2-3, And perhaps a bad driver.
as for repairing the ports themselves I am not sure what i can say to help you, But in my opinion i would just add a PCI USB card.
这个答案有帮助吗?
得分 0
3条评论:
Thank you...
完成的
Don't know why i was down voted. kinda stupid.
完成的
Yep, that was odd.
完成的
添加一条评论
添加你的答案
Deepro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,317
