第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
3260 个问题 查看全部
volume buttons and sound on/off not working.
I replaced my moms iPhone 4 screen and now the volume buttons and silent on/off button stopped working.
I thought maybe it was the headphone jack and volume control cable but the headphone jack is still working.
Could the cable still be bad even though the headphone jack is still working?
I have already tried to restore and hard reset it. so it must be a hardware problem.
Let me know which part it is i would need to order.
Thank you so much for you help :-)
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
I already went back through and tried that. I ordered the part I need. Im hoping it will fix my problem. Thank you for you help :-)
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
4个回答
已选择的解决方案
Maybe the Flex connector is not perfectly snapped down on the Logic Board Connector. May be worthwhile to retrace your steps and try to reconnect that connector.
And, yes, multifunction Flex cables can have damage to individual functions.
这个答案有帮助吗?
按维修分数 1
添加一条评论
The volume flex is not attached to the power button on the iphone 4 it is volume mute headphone jack Power is attached to the proximity sensor / noise cancelling microphone. You probably do need to replace it though. Puru is referring to the 3g/3gs.
这个答案有帮助吗?
按维修分数 1
添加一条评论
You just happened to cut/tear it during assembly. Replace it. It is also connected to the power switch so have to replace it as entire set. It's a single part and won't cost much.
这个答案有帮助吗?
按维修分数 0
添加一条评论
My problem was the flex audio jack .....less than 2.00 . A great video explaining it here....
http://www.youtube.com/watch?v=AZI5tMd5p...
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
martiball10 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 848
