Msi CR 630 laptop not charging
Loose power supply jack which is connected to the motherboard! Can it be repaired?
Gareth Roberts, most of the DC jacks are soldered onto the logic board. Yes they can be repaired by either replacing them, or re-soldering the connection. This will require that you remove your motherboard. Of course you will have to have soldering tools, as well as know how to solder.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 738
