My PSP 1000 will no longer charge from the wall?
My PSP was charging fine, have had it about 3 yrs now went to plug it in the other day and now nothing will not power on and does not charge from the wall or via usb by computer. Please help.
Dwayne Thomas, first off, make sure that your charger is working right. check the output with a multimeter. If it works, you want to check your battery, it is possible that it is at the end of its lifespan and needs to be replaced. Then there is the possibility that your power fuse has tripped. You want to check for continuity on that. Check here for more info on that. Hope this helps, good luck.
这个答案有帮助吗?
Thanks will try this out as soon as I get home and let you know what happens.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 664
