The M11x R2 (Revision 2) is Alienware's 11 inch updated version of the original M11x laptop, featuring a i5 520UM or a i7 740UM processor in the american models.
4 个问题 查看全部
Computer is running slow. Graphics are lagging badly.
The M11xR2 has coped well in the past but lately in on line games it is lagging very badly with a FPS rate below 10. I have upgraded drivers and have made sure the Nvidia graphics card is set to run high performance but it makes no difference. I don't think the problem is overheating as even when just turned on the problem is there. It makes no difference if it is cabled or wireless connections. Any help would be appreciated.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
5个回答
已选择的解决方案
Here is a link to a source for manuals including service manual for your computer. Hope this helps.
http://support.dell.com/support/edocs/sy...
这个答案有帮助吗?
按维修分数 1
添加一条评论
If your Hardware is pretty much compatible with game requirements than you have to go through some points before playing game to prevent your PC from slowing down:-
- Shut down all running updates
- Remove all temporary files from your system
- You must have enough memory on disc that can support your paging memory
- Shut down all background running applications
- Run Reginout Utility for extreme gaming experience
- Update DX on your system
Thanks, Hope I helped.
这个答案有帮助吗?
按维修分数 1
添加一条评论
this can be fixed in few simple steps just follow - remove all other unwanted programs from you computer and all unwanted add on , clear junks and trojans if u have and restart the system
thanks
这个答案有帮助吗?
按维修分数 1
添加一条评论
Hi,
Facing lag dose not always mean the problem is with your VGA only you might experience lag due to some other process holding the processor to cause a memory choke for system processes. Try extending the memory (RAM) for your laptop and see if you still face lags in while gaming.
Good Luck
这个答案有帮助吗?
按维修分数 0
添加一条评论
Overheating can occur straight away if there is dust inside:
http://forum.notebookreview.com/alienwar...
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Anthony Kearns 将永远感激不已
浏览统计数据:
过去的24小时: 6
过去的7天: 41
过去的30天: 178
总计 9,675
