跳转到主内容
ATV2 thinks it's on ethernet even when ethernet cable is unplugged
ATV2 keeps saying that "to switch to wifi, remove the ethernet cable". The ethernet cable is NOT plugged in yet ATV2 thinks its is.
Even when I plug an ethernet cable and sometimes configure the connection manually, it does not connect at all.
So with the ethernet cable plugged it does not work, and when unplugged, the ATV2 things it is plugged, hence no wifi! :-(
Any help please? Thanks guys
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You have a damaged ethernet port. Probably will have to replace the logic board. AS A WORK AROUND go to System Preferences:Network and remove (delete) the Ethernet Service. This may allow you to use only wireless or a USB Ethernet dongle.
If this answer was helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ibrahim Lahoud 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,534
