<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Sega Master System&quot;]]></title>
<link>https://zh.ifixit.com/Answers/Device/Sega_Master_System?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Sega Master System&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 08 Aug 2026 15:03:11 -0700</pubDate>
<item>
<title><![CDATA[Sega Master System: Button 2 on controller port 1 not working]]></title>
<description><![CDATA[<p>Hi there! I have a NTSC (USA) Master System and button 2 is not working on controller port 1. I have two original controllers and both work perfectly when connected to controller port 2, but if I connect to port 1, button 2 won’t work. I tried resoldering all 9 pins for controller port 1, but problem persists. Any idea what might be wrong? Thank you!</p>
<p>⟐ Commented 一月 10, 2022 at 15:12 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/630644/Button+2+on+controller+port+1+not+working</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/630644</guid>
<pubDate>Mon, 10 Jan 2022 15:12:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Sega Master System: Controlllers will not start the game]]></title>
<description><![CDATA[<p>Hi, the system powers up and displays the game but the game does not start when I hit the start button on the controller.  Thank you</p>
<p>⟐ Answered 八月 15, 2020 at 4:08 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/636108/Controlllers+will+not+start+the+game</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/636108</guid>
<pubDate>Sat, 15 Aug 2020 04:08:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Sega Master System: Sega master system mk1.]]></title>
<description><![CDATA[<p>I own multiple sega master systems ,  all great condition but in a postion where i can only keep one. My spanish bought model is the best condition but am concerned a uk power adapter will blow it.</p>
<p>Living in the uk will my spanish bought sega master system be safe using a uk version psu?</p>
<p>Thanks in advance.</p>
<p>⟐ Edited 十一月 02, 2019 at 21:47 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/599711/Sega+master+system+mk1.</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/599711</guid>
<pubDate>Sat, 02 Nov 2019 21:47:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Sega Master System: Can I use uk psu on canadian sms?]]></title>
<description><![CDATA[<p>Im based in the uk, can i use a uk sega master system psu  on a french sega master system?</p>
<p>⟐ Commented 十一月 02, 2019 at 13:15 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/599590/Can+I+use+uk+psu+on+canadian+sms</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/599590</guid>
<pubDate>Sat, 02 Nov 2019 13:15:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Sega Master System: Sega Master System Audio/Video Problem]]></title>
<description><![CDATA[<p>My SEGA Master System has a audio/video problem, that always requires  consistent fiddling around with the audio/video cables/connectors both on the television and the game console itself. What should I do?</p>
<p>⟐ Commented 四月 18, 2019 at 13:29 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/562154/Sega+Master+System+Audio-Video+Problem</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/562154</guid>
<pubDate>Thu, 18 Apr 2019 13:29:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Sega Master System: Sega Master System Power Supply]]></title>
<description><![CDATA[<p>I wanted to ask what kind of power supply does a SMS use? AC/DC? 9-12V? Does Sega Mark III and SMS Model 1 &amp; 2 have the same Power Supplies?</p>
<p>⟐ Commented 十一月 09, 2017 at 0:07 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/439274/Sega+Master+System+Power+Supply</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/439274</guid>
<pubDate>Thu, 09 Nov 2017 00:07:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Sega Master System: Powers on but won’t read games.]]></title>
<description><![CDATA[<p>System powers on but won’t read games from cartridge.</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/942122/Powers+on+but+won%E2%80%99t+read+games.</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/942122</guid>
<pubDate>Tue, 24 Feb 2026 21:55:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[Sega Master System: Why is my output an incorrect display color?]]></title>
<description><![CDATA[<p>Why would my console display a green output color where there should be white? The result is the same weather using the RF port or the composite ports and I noted the saturation will change from time to time but never to the point that it is the proper white output.</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/935234/Why+is+my+output+an+incorrect+display+color</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/935234</guid>
<pubDate>Sat, 10 Jan 2026 08:02:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Sega Master System: Fixing a Sega Master System game]]></title>
<description><![CDATA[<p>Hello,</p>
<p>I been trying to get a Sega Master System game to work called R-type. Unfortunately I haven't had any success and believe that its the chips itself having problems. I then discovered a video on youtube based on fixing Sega Genesis games that testing pins of the chip using the diode mode on a multimeter, from ground to the pin, and if I had one pin from the chip that doesn't allow any current, to solder a 1k resistor to complete the circuit from the pin and ground. I tested that on a genesis game that had the same problem, and it works!</p>
<p>Video here: <a href="https://www.youtube.com/watch?v=eCT4ZKV20RI&amp;t=161s" title="https://www.youtube.com/watch?v=eCT4ZKV20RI&amp;amp;t=161s">https://www.youtube.com/watch?v=eCT4ZKV2...</a></p>
<p>My question is, is that possible to do the same technique with a Sega master system game? If so, what resistor should I use?</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/768308/Fixing+a+Sega+Master+System+game</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/768308</guid>
<pubDate>Tue, 07 Feb 2023 17:30:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Sega Master System: Power Converter and Supply]]></title>
<description><![CDATA[<p>I tried to fix my Sega Master System myself but failed. I took out the Power Converter and the hole you plug the power supply into. I really wan’t to get it fixed but I can’t find the parts anywhere because I don’t know the names really. Do you know what I need?</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/666744/Power+Converter+and+Supply</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/666744</guid>
<pubDate>Wed, 18 Nov 2020 09:56:16 -0700</pubDate>
</item>
</channel>
</rss>
