<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Samsung Washing Machine WW6800K Series&quot;]]></title>
<link>https://zh.ifixit.com/Answers/Device/Samsung_Washing_Machine_WW6800K_Series?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Samsung Washing Machine WW6800K Series&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 03 Aug 2026 11:40:17 -0700</pubDate>
<item>
<title><![CDATA[Samsung Washing Machine WW6800K Series: SAMSUNG washing machine doesn't power up]]></title>
<description><![CDATA[<p>I have a washing machine that has stopped in the middle of a cycle and showed an 'UC' error. On the SAMSUNG's site it says that is <strong>is related to the excessive fluctuation of the power supply voltage</strong>. I turned it off and now it doesn't turn on anymore.<br /><br />Analyzing the main board, I've checked low voltage power supply and it seems to work, it outputs 37V (or something like that, I don't remember the exact value). On some connectors I've measured 5V and 12V.<br /><br />In the same board there is also a relay connected to the input that, when active, powers other components (like the door lock) and the main rectifier circuit that powers the inverter.<br />If I bypass that, the machine turns on and after a couple of seconds I can hear the relay activating. At this point I can remove the bypass and the machine stays on. (I haven't tried to run a cycle)<br /><br />At this point I'm not sure on what is the problem. The description of the error code makes me think that it has something that measures some kind of voltage? (I don't know what it checks and where), so maybe that is faulty? Or I'm missing something else?<br /><br />I've attached a simplified schematic  that I've drawn while trying to understand how it works.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DDwhjDMluFaExK3h.standard" width="282" height="167" class="hasMenu hasLarge" alt="图片" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DDwhjDMluFaExK3h.full&quot;, '', 'width=1186,height=702')" /></div>
<p><br />Moreover, I've found a service manual online that have some details on the wirings: <a href="https://www.manualslib.com/manual/2797277/Samsung-Ww6000j-Series.html" rel="nofollow noopener noreferrer" title="https://www.manualslib.com/manual/2797277/Samsung-Ww6000j-Series.html" target="_blank">https://www.manualslib.com/manual/279727...</a></p>
<p>Do you have any suggestions? Thanks.</p>
<p>⟐ Edited 十二月 28, 2023 at 10:06 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/800500/SAMSUNG+washing+machine+doesn&#039;t+power+up</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/800500</guid>
<pubDate>Thu, 28 Dec 2023 10:06:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine WW6800K Series: Error code 5C not draining]]></title>
<description><![CDATA[<p>Having a nightmare with my samsung washer, I have had the code 5C and 5UD.</p>
<p>Lint filter is clear</p>
<p>Waste hose is clear with no kinks</p>
<p>Drain pump replaced</p>
<p>Hoses from drum to pump clear</p>
<p>Water level sensor clear but not replaced.</p>
<p>Any ideas</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/921565/Error+code+5C+not+draining</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/921565</guid>
<pubDate>Sun, 12 Oct 2025 12:35:18 -0700</pubDate>
</item>
</channel>
</rss>
