<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Nest Security Camera&quot;]]></title>
<link>https://zh.ifixit.com/Answers/Device/Nest_Security_Camera/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Nest Security Camera&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 07 Sep 2026 02:27:53 -0700</pubDate>
<item>
<title><![CDATA[Nest Hello: Tiny solid rubber block inside housing]]></title>
<description><![CDATA[<p>Where does a 1/8” x 1/4” rubber block go inside component? It fell out when I took off black plate</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/966462/Tiny+solid+rubber+block+inside+housing</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/966462</guid>
<pubDate>Sun, 02 Aug 2026 05:00:55 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Cam Outdoor: What is the function of all these wires]]></title>
<description><![CDATA[<p>My Google camera GJQ9T has a wire that runs between the camera and the power supply that plugs into the 120 outlet.     I needed to cut the cable, now I have to repair the cut wire.    From what I read the camera needs 5 volts, therefore I should need only 2 wires.    Inside the cable I find 2 red wires, 1 white wire, 1 green wire, 1 wire for the shield.   What is the function of all these wires, which ones should I use</p>
<p>Thank you</p>
<p>Steve</p>
<p>⟐ Commented 一月 17, 2026 at 23:44 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/936427/What+is+the+function+of+all+these+wires</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/936427</guid>
<pubDate>Sat, 17 Jan 2026 23:44:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest cam outdoor: Hardwiring the Nest Cam Outdoor]]></title>
<description><![CDATA[<p>My house is new construction and has a low voltage hardwire in place for a security camera. I want to wire the Nest Cam Outdoor to this hardwire. Any thoughts on how it should be spliced and attached. Could I just cut the USB cable and attach the power wires directly to the house hardwiring?</p>
<p>⟐ Answer edited 一月 17, 2026 at 12:06 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/370101/Hardwiring+the+Nest+Cam+Outdoor</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/370101</guid>
<pubDate>Sat, 17 Jan 2026 12:06:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Cam: My QR code has faded how do I add the device to my google home?]]></title>
<description><![CDATA[<p>The QR code on the back has faded. I need to add this device. How can I do so?</p>
<p>⟐ Answered 九月 29, 2025 at 0:02 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/919561/My+QR+code+has+faded+how+do+I+add+the+device+to+my+google+home</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/919561</guid>
<pubDate>Mon, 29 Sep 2025 00:02:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Hello: not working Nest Hello]]></title>
<description><![CDATA[<p>two devices were installed and working then after two weeks not working and not even a light .</p>
<p>⟐ Commented 九月 19, 2025 at 4:32 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/633889/not+working+Nest+Hello</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/633889</guid>
<pubDate>Fri, 19 Sep 2025 04:32:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Cam Outdoor: Google Nest Cam will not connect]]></title>
<description><![CDATA[<p>I have tried every way possible but I cannot get it to connect.  I have a second nest cam that works perfectly.  The next cam with the problem is fairly close to my router. I have done a factory reset and still nothing.  The set up process goes well until the final phase and it just then says that it &quot;encountered a problem&quot;. The camera worked well for over a year until one day it stopped connecting. All effort to reconnect have failed.  :-(</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/915818/Google+Nest+Cam+will+not+connect</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/915818</guid>
<pubDate>Sat, 06 Sep 2025 09:48:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Cam Outdoor: Nest Cam Outdoor has died - no power light at all]]></title>
<description><![CDATA[<p>Anyone tried repairing one of these?</p>
<p>⟐ Commented 七月 27, 2025 at 9:16 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/690231/Nest+Cam+Outdoor+has+died+-+no+power+light+at+all</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/690231</guid>
<pubDate>Sun, 27 Jul 2025 09:16:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Cam: My nest cam gives me a message "video not available yet, check back la]]></title>
<description><![CDATA[<p>Later&quot; never shows the video. This is one of 3 cameras, the others work perfectly.</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/907753/My+nest+cam+gives+me+a+message+%22video+not+available+yet,+check+back+la</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/907753</guid>
<pubDate>Wed, 16 Jul 2025 17:51:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Cam: Rated M for mature, can I replace the power port & the mic on my nest]]></title>
<description><![CDATA[<p>First, I’ll start with when Google 🚨 purchased nest, when migrating over to Google 🚨 I ran into some issues and I had to call guess who? Yeah, Google 🚨, the tech-support walked me through resetting my Nest cams, and during that process, they had me take a metal paper clip and stick it right in a tiny reset hole on the bottom rim of the camera they said, hold it there and press firmly and wait until the light flashes. I did exactly as Google 🚨 instructed and nothing happened, to further troubleshoot they had me do it to get another cam. I acquiesce the request and again nothing happened. Couple more attempts and they said well we could do it from our end. OK, thinking to myself jackasses why didn’t you do that 30 minutes ago.?</p>
<p>Well, we got the cameras up and running long after that I started to realize my sound sucked out of warranty and Google 🚨’s not gonna do anything about it. It’s not their problem right? Now years later infinitely smarter, which is insane much. As I have ingrained myself deep within the DIY community and the &amp;&amp;^&amp; yourself I can do it for way less you gouging Theiving bastards. ( thinking of the time my insurance company gave me $14,000 to repair the flood damage to my home and not only did I repair them all, but I upgraded everything doing it myself for a little more than 1200 bucks.)</p>
<p>In the process of doing so I uncovered a little known fact…… that wasn’t a reset yet jackasses! That wasn’t my %#*@ mic you had me poking with a metal paper clip with firm pressure! Essentially, Google 🚨 took over nest and then had tech-support sabotage and destroy my cameras, forcing me to upgrade them! Cocksuckers I feel like there’s a class action suit there, not to mention come on. I’m not that paranoid guy that thinks it was just me! How many other people out there the Google 🚨 have jamming things into their microphone essentially destroying them?</p>
<p>But I digress during this exploratory mission to fix an original nest drop cam that the slightest touch would cause it to disconnect because the power port was coming loose!</p>
<p>Which brings me back to good old iFixit!</p>
<p>Is it possible to replace the Mic in the power port on the original, I believe GEN two nest cams drop cam?</p>
<p>If so, could someone kindly direct me to the parts to do so?</p>
<p>Same project bonus question, can I upgrade those old Micro B Cables, also known as the android cable, also known as the most fidgety &amp;&amp;^&amp;^$^ cable in existence?</p>
<p>Bonus bonus question who’s with me let’s sue Google 🚨 for being jackasses! Just kidding unless there’s a really bad ass attorney reading this right now yeah dude hit me up lol.</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/877202/Rated+M+for+mature,+can+I+replace+the+power+port+&amp;+the+mic+on+my+nest</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/877202</guid>
<pubDate>Fri, 15 Nov 2024 06:56:55 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Cam Outdoor: condensation appearing inside lens interior]]></title>
<description><![CDATA[<p>Last week (after about 26 months of functionality) condensation appeared on our Nest Outdoor Cam. Any ideas how to remedy?</p>
<p>⟐ Answer edited 十一月 13, 2024 at 5:26 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/760300/condensation+appearing+inside+lens+interior</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/760300</guid>
<pubDate>Wed, 13 Nov 2024 05:26:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Cam: Which red wire to splice to a red wire]]></title>
<description><![CDATA[<p>On my nest cam i have 2 red wires ,1 green and 1 white. My dog chewed thru the cord and i want to rewire buy splicing the wires. But my question is why are there 2 red wires and how to find the right red wire on the other piece that I'm trying to splice.</p>
<p>⟐ Answered 十月 27, 2024 at 12:01 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/875156/Which+red+wire+to+splice+to+a+red+wire</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/875156</guid>
<pubDate>Sun, 27 Oct 2024 12:01:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest x Yale Lock: How to lube the motor on my lock?]]></title>
<description><![CDATA[<p>When I turn the knob to lock my lock it seems to be a little noisy. Is there a way to oil or grease it?</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/872418/How+to+lube+the+motor+on+my+lock</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/872418</guid>
<pubDate>Sun, 06 Oct 2024 20:57:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Hello: Boot Loop after replacing battery]]></title>
<description><![CDATA[<p>After replacing the battery and reassembly of the doorbell, my 1st Gen wired Nest Hello Doorbell is stuck in a Boot Loop.  The blue light never pulses indicating ready to connect to the local network.  The blue light surrounding the doorbell button lights momentarily and then the green LED at the top of the unit flashes, the blue light goes out and the process repeats endlessly.  This happens both when hardwired to the transformer and when the USB port is used.  Has anyone seen this behavior?</p>
<p>⟐ Commented 九月 18, 2024 at 12:43 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/839927/Boot+Loop+after+replacing+battery</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/839927</guid>
<pubDate>Wed, 18 Sep 2024 12:43:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Hello: How to find a replacement ribbon cable for Nest doorbell 2nd gen, batt]]></title>
<description><![CDATA[<p>While attempting to remove the nest doorbell without the correct tool, I accidentally popped the front plate from the rear portion. The ribbon cable that joined the two was severed. Called Google, but they don't seem to have these kinds of replacement parts. It seems a shame to trash the unit for lack of a small cable.  Any ideas?</p>
<p>⟐ Answered 八月 28, 2024 at 9:23 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/862443/How+to+find+a+replacement+ribbon+cable+for+Nest+doorbell+2nd+gen,+batt</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/862443</guid>
<pubDate>Wed, 28 Aug 2024 09:23:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest IQ Outdoor Camera: no longer powers on]]></title>
<description><![CDATA[<p>My Nest Outdoor wired Camera has stopped turning on. Wire is good and power adapter is good. Can it be fixed?</p>
<p>⟐ Answered 三月 25, 2024 at 0:04 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/775389/no+longer+powers+on</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/775389</guid>
<pubDate>Mon, 25 Mar 2024 00:04:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Cam Outdoor: How do you get into the camera piece to re hook the wire connectors]]></title>
<description><![CDATA[<p>camera wiring was pull out of the camera housing. need to re attach...how do you open the camera housing to get at the inside\</p>
<p>⟐ Answered 一月 15, 2024 at 21:17 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/832387/How+do+you+get+into+the+camera+piece+to+re+hook+the+wire+connectors</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/832387</guid>
<pubDate>Mon, 15 Jan 2024 21:17:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Cam: Cut and repair the power cable to the outside nest cam?]]></title>
<description><![CDATA[<p>I bought the outside nest cam but the connector is like 3/4 around. Trying to fish that through the soffit is quite hard. I'm pretty technical but cutting the power supply and repairing on a $250 camera seems somewhat risky if I mess it up. My question is on the line that is connected to the camera if I cut it is it easy to repair?</p>
<p>⟐ Commented 十二月 13, 2023 at 6:06 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/344651/Cut+and+repair+the+power+cable+to+the+outside+nest+cam</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/344651</guid>
<pubDate>Wed, 13 Dec 2023 06:06:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Hello: Where to get the faceplate?]]></title>
<description><![CDATA[<p>Where can I buy the faceplate for a nest hello wired doorbell?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_01_18_Num_2022" class="header">Update (01/18/2022)</h3></div>
<p>I’m talking about the black faceplate for the doorbell that has  the rubber gasket around it.  Mine is pealing and out of warranty and Google won’t sell me one.  I’d probably need the rubber gasket too.  This is the first part you remove in getting inside the Nest Hello to change the battery or anything else.</p>
<p>⟐ Answer edited 十二月 09, 2023 at 16:22 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/718494/Where+to+get+the+faceplate</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/718494</guid>
<pubDate>Sat, 09 Dec 2023 16:22:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Hello: Where to find replacement gasket?]]></title>
<description><![CDATA[<p>Where can one find the replacement gasket?</p>
<p>The replacement of this piece is mentioned in its own guide as well as in the battery replacement guide.  I have not been able to find with basic search terms.</p>
<p>Thank you in advance!</p>
<p>⟐ Answered 十月 24, 2023 at 2:15 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/820753/Where+to+find+replacement+gasket</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/820753</guid>
<pubDate>Tue, 24 Oct 2023 02:15:03 -0700</pubDate>
</item>
</channel>
</rss>
