<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Maytag Washing Machine&quot;]]></title>
<link>https://zh.ifixit.com/Answers/Device/Maytag_Washing_Machine/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Maytag Washing Machine&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Thu, 03 Sep 2026 04:02:50 -0700</pubDate>
<item>
<title><![CDATA[Maytag Washing Machine: Remove drive hub on Maytag Bravos MCT MVWX655DW1]]></title>
<description><![CDATA[<p>Everything I read and watched shows people able to remove their agitator plate, remove the retaining clip on their drive hub, remove the 6 screws, and then slide the drive hub up and off the drive shaft. The upper drive shift and fins that the agitator slides onto is larger than all the videos I've seen, and my drive hub cannot slide past it. Pictures provided.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/edXFR6N2gxoEYXGC.standard" width="282" height="211" class="hasMenu hasLarge" alt="图片" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/edXFR6N2gxoEYXGC.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/jw21uPFKRHi2DgiG.standard" width="282" height="211" class="hasMenu hasLarge" alt="图片" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/jw21uPFKRHi2DgiG.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/bdlDDWEn5gSbjWHM.standard" width="282" height="211" class="hasMenu hasLarge" alt="图片" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/bdlDDWEn5gSbjWHM.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/euQlsqLSmcexSoG1.standard" width="282" height="211" class="hasMenu hasLarge" alt="图片" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/euQlsqLSmcexSoG1.huge&quot;, '', 'width=1600,height=1200')" /></div>]]></description>
<link>https://zh.ifixit.com/Answers/View/970548/Remove+drive+hub+on+Maytag+Bravos+MCT+MVWX655DW1</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/970548</guid>
<pubDate>Mon, 31 Aug 2026 07:35:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Bravos quiet series 300: Why will my washer not fill at beginning of cycle?]]></title>
<description><![CDATA[<p>I have a 2009 Maytag Bravos Quiet Series 300 washing machine -- model number MVWB700VQ0. We just moved to a new house, and as far as I know it was working fine in the old house.</p>
<p>Now, the cycle starts and water sprays in the machine, then the water runs through the detergent cup. The machine spins to balance the load, and when the tub slows to fill, nothing happens. Doesn't matter what cycle or water temperature, no water is added to the main tub for about the first 8 minutes of the cycle. After that, it kicks in and starts adding water, washes, rinses and drains as normal. I'm not getting any error codes.</p>
<p>We checked hoses, water pressure and screens. Thought it might be the water intake valve, but since it's working at other stages in the cycle, it's not that. Does this mean I have a timing issue or something with the main computer component? Again, I've not had any problem that I was aware of until we moved it after it'd been in the same place for 7 years.</p>
<p>Thanks for your help!</p>
<p>⟐ Edited 八月 13, 2026 at 1:55 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/316111/Why+will+my+washer+not+fill+at+beginning+of+cycle</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/316111</guid>
<pubDate>Thu, 13 Aug 2026 01:55:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag bravos xl: Diagnostic Mode F8 stuck at C8]]></title>
<description><![CDATA[<p>Maytag MVWB950 series top loader. It’s not draining and when going to diagnostic mode after it flash 88:88 it show F32. It cycle through C0 and at C8 it just slowly agitate, but won’t spin or drain. It stuck at C8.</p>
<p>Replaced the drain pump and went through reset and calibration cycle. It goes through all the cycles and stop at spin cycle.</p>
<p>If you press power off, it then locks the panel and beep at any button pressed.</p>
<p>Any idea what the issue is?</p>
<p>Much appreciated.</p>
<p>⟐ Commented 八月 02, 2026 at 23:29 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/813675/Diagnostic+Mode+F8+stuck+at+C8</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/813675</guid>
<pubDate>Sun, 02 Aug 2026 23:29:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washer MVWB765W: Draining problems (not clogged)]]></title>
<description><![CDATA[<p>When I run my washing machine, it will get hung up when it is time to drain. The machine will have a buzzing sound and the water will not drain. Sometimes I will get a DRN error code. If I reset the machine, sometimes that works and it will drain. Other times I will have to reset it multiple times before it works. Sometimes I can run 10 loads of laundry and it never has an issue. <br /><br />I took it apart, cleaned the hose, pump looked good. Had a repairman look at it, he also said the pump was good. Any help?</p>
<p>⟐ Commented 七月 18, 2026 at 13:14 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/706496/Draining+problems+(not+clogged)</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/706496</guid>
<pubDate>Sat, 18 Jul 2026 13:14:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Bravos quiet series 300: UL code always comes on what can I do to fix?]]></title>
<description><![CDATA[<p>My Maytag bravo quiet series 300 washer runs for about 10 minutes then the &quot;UL &quot; code comes up and I tried to level the load out . I even made sure the inside drum is level. Can you please help me fix the problem???</p>
<p>⟐ Commented 七月 14, 2026 at 18:11 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/321588/UL+code+always+comes+on+what+can+I+do+to+fix</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/321588</guid>
<pubDate>Tue, 14 Jul 2026 18:11:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Bravos quiet series 300: Loud grinding noise during pump operation.]]></title>
<description><![CDATA[<p>Why is my pump making a loud grinding noise?  Is it pump failure or do I need to pull the basket and check for restrictions in the drain?</p>
<p>⟐ Answered 六月 25, 2026 at 8:41 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/961071/Loud+grinding+noise+during+pump+operation.</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/961071</guid>
<pubDate>Thu, 25 Jun 2026 08:41:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washing Machine: Maytag top loader will not fill and not spin, time for a new board?]]></title>
<description><![CDATA[<p><strong>Model Number:</strong> MVW7230HW1<br /><strong>Main Symptom: Won’t spin, won’t fill</strong><br /><strong>What happens &amp; when: When I start a wash cycle, no water fills, basket/tub does not spin, and then cycle jumps to complete.</strong></p>
<p>Error Code (if any): F6E3, F7E7, F7E4, F7E3<br />Parts or tests already tried:</p>
<ol><li>I tried replacing the actuator<ol><li>Similar situation: would not fill, would not spin</li><li>However, new actuator did allow the cycle to run the duration rather than jump to complete</li></ol></li><li>I checked the clutch assembly<ol><li>no signs of wear, plastic teeth look good</li></ol></li><li>Checked the stator for continuity, and had resistance on its pins at the harness</li><li>Checked the wires from the board to the stator, and those tested fine</li><li>the water/fill/pressure tube has no blockage in it, it’s clear</li><li>I can manually spin the basket/drum with no issues<ol><li>nothing is impeding it from spinning</li></ol></li><li>The rotor spins smoothly, clogging to magnets of course.</li><li>the magnets on the stator are fine as well.</li><li>When I run the diagnostic mode:<ol><li>water fills</li><li>drains</li><li>basket does not move at all</li></ol></li></ol>
<p>⟐ Commented 六月 15, 2026 at 7:20 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/958119/Maytag+top+loader+will+not+fill+and+not+spin,+time+for+a+new+board</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/958119</guid>
<pubDate>Mon, 15 Jun 2026 07:20:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washing Machine: Maytag washing machine issue]]></title>
<description><![CDATA[<p>maytag washer just shuts off when trying to turn the dial and doesn't run cycles Please see the attached video .<a href="https://vimeo.com/1200789977?share=copy&amp;fl=sv&amp;fe=ci" rel="nofollow noopener noreferrer" title="https://vimeo.com/1200789977?share=copy&amp;amp;fl=sv&amp;amp;fe=ci">https://vimeo.com/1200789977?share=copy&amp;...</a></p>
<p>Any idea whats happening here</p>
<p>⟐ Edited 六月 12, 2026 at 7:48 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/959370/Maytag+washing+machine+issue</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/959370</guid>
<pubDate>Fri, 12 Jun 2026 07:48:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washing Machine: front load washer will not spin. It goes through all cycles, no spin]]></title>
<description><![CDATA[<p>I have a Maytag front load washing machine, model <strong>YMHWE301YW00.  It will go through the entire cycle, the time is there for the spin, but the hopper will not spin out the clothes. Tried it full, empty, some clothing, same result. Everything else operates as it should. At a loss. A new control module is almost $400, then there is 2 of them??</strong></p>
<p>⟐ Answered 六月 11, 2026 at 1:08 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/959160/front+load+washer+will+not+spin.+It+goes+through+all+cycles,+no+spin</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/959160</guid>
<pubDate>Thu, 11 Jun 2026 01:08:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washer MVWB765W: Why do I have lint all over my dark colored clothes?]]></title>
<description><![CDATA[<p>How come I keep getting lint all over my dark colored clothes?</p>
<p>⟐ Answered 六月 07, 2026 at 7:38 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/958617/Why+do+I+have+lint+all+over+my+dark+colored+clothes</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/958617</guid>
<pubDate>Sun, 07 Jun 2026 07:38:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Bravos quiet series 300: How can I reset Bravo 300 f54 code]]></title>
<description><![CDATA[<p>I have taken apart drum cleaning any coins clearing any thing away from ports. Still getting f54 code is theur a,reset please help</p>
<p>⟐ Answer accepted 六月 03, 2026 at 21:50 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/236416/How+can+I+reset+Bravo+300+f54+code</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/236416</guid>
<pubDate>Wed, 03 Jun 2026 21:50:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag A107 (1980ish): My washer fills up with water but then the agitator won't work]]></title>
<description><![CDATA[<p>My washer fills up but the agitator won't work</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_05_29_Num_26" class="header">Update (05/29/26)</h3></div>
<p>My washer fills up with water but the agitator won't work</p>
<p>⟐ Edited by author 五月 29, 2026 at 14:41 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/957405/My+washer+fills+up+with+water+but+then+the+agitator+won&#039;t+work</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/957405</guid>
<pubDate>Fri, 29 May 2026 14:41:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washer MVWB765W: MOD# mvw5430mw0 SCREAMING PUTTING WATER IN]]></title>
<description><![CDATA[<p>The Maytag washer is Screaming! when it fills with water. to the point it hurts my ears. This MODEL # mvw5430mw0 is not here. Is there someone that can help?</p>
<p>⟐ Commented 五月 24, 2026 at 8:53 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/956410/MOD%23+mvw5430mw0+SCREAMING+PUTTING+WATER+IN</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/956410</guid>
<pubDate>Sun, 24 May 2026 08:53:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washing Machine: Maytag Bravo X clicking, then eventually starts to spin]]></title>
<description><![CDATA[<p><strong>Brand: Maytag</strong><br /><strong>Model Number: MVWX700XL2</strong><br /><strong>Main Symptom: Clicking then eventually spins</strong></p>
<p>Hi all, having an issue with our <strong>MVWX700XL2 washing machine. Over the past 1+ year, when starting and periodically during a wash, the unit will start clicking. It’s like it’s trying to kick on the spin then after so many times it will eventually catch and spin. Whatever, it’s still been working and completing loads all this time.</strong></p>
<p>However over the past week it’s gotten worse, it will continually click and never catch and spin the drum… after so long it will eventually give up and the washer turns off. Then we go to start it again and it will click for a while and catch and start spinning and do the complete wash as usual.</p>
<p>Any idea what this is? It’s like a relay clicking but not fully engaging the drum to spin.</p>
<p>Here is a short video:</p>
<p><a href="https://syswirx.com/downloads/bravox.mp4" rel="nofollow noopener noreferrer">https://syswirx.com/downloads/bravox.mp4</a></p>
<p>Thanks all!</p>
<p>⟐ Edited 四月 30, 2026 at 8:20 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/952795/Maytag+Bravo+X+clicking,+then+eventually+starts+to+spin</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/952795</guid>
<pubDate>Thu, 30 Apr 2026 08:20:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washer MVWB765W: Washer will not fill with water]]></title>
<description><![CDATA[<p>Will not fill with water.  No valve blockage and electric valves open and close when bench tested.  Control board was tested and it too is not the problem.</p>
<p>⟐ Commented 四月 15, 2026 at 14:46 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/577899/Washer+will+not+fill+with+water</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/577899</guid>
<pubDate>Wed, 15 Apr 2026 14:46:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washing Machine: du/dl error: replaced lid lock no change]]></title>
<description><![CDATA[<p>MAYTAG BRAVOS 400 SERIES MVWB800VQ0</p>
<p>Replaced Lid Lock W10059230 with Maytag recommended replacement W10619844 lid lock. No change in error code of DL/DU, DU specifically.</p>
<p>I dismounted the new lock and left it outside the enclosure where it was observable and while the old lock reacts and attempts to lock, the new lock does not react at all.</p>
<p>Any ideas?</p>
<p>⟐ Commented 四月 10, 2026 at 18:30 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/947963/du-dl+error:+replaced+lid+lock+no+change</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/947963</guid>
<pubDate>Fri, 10 Apr 2026 18:30:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washing Machine: The stator on washing machine motor 1/2hp has some uneven spacing]]></title>
<description><![CDATA[<p>It's a new motor. I noticed the uneven spacing and the yellow mark while pulling motor out of the box. It has a T shape marking from the factory. Hopefully means: &quot;Tested&quot;. Anyone knows what that means? Also some o the cardboard got stack on the lamination on one corner due to rough handling. I tried to brush if off buy it's stuck. I am guessing that's not a problem since there are stickers on the stator anyway... Thanks</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/CcXVDJaxE2dsFFls.standard" width="169" height="225" class="hasMenu hasLarge" alt="图片" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/CcXVDJaxE2dsFFls.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/BeXAKtSaUVM55ekN.standard" width="169" height="225" class="hasMenu hasLarge" alt="图片" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/BeXAKtSaUVM55ekN.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented 三月 23, 2026 at 14:48 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/929222/The+stator+on+washing+machine+motor+1-2hp+has+some+uneven+spacing</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/929222</guid>
<pubDate>Mon, 23 Mar 2026 14:48:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Bravos quiet series 300: Why does it take so long for my Maytag to wash clothes?]]></title>
<description><![CDATA[<p>The &quot;Normal&quot; cycle is :41 minutes total...or so it says.  But, it takes 1:10 minutes to wash!! Why??</p>
<p>⟐ Commented 二月 25, 2026 at 19:32 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/338310/Why+does+it+take+so+long+for+my+Maytag+to+wash+clothes</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/338310</guid>
<pubDate>Wed, 25 Feb 2026 19:32:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washer MVWB765W: Lid switch malfunction, how can I bypass this switch]]></title>
<description><![CDATA[<p>I have a lid switch malfunction ,how can I bypass this switch</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/942038/Lid+switch+malfunction,+how+can+I+bypass+this+switch</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/942038</guid>
<pubDate>Tue, 24 Feb 2026 09:09:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag Washing Machine: What is the proper belt tension on a MHN33PDCWW0?]]></title>
<description><![CDATA[<p>We have 6 MHN33PDCWW0 front loaders in our RV park that are</p>
<p>Over 11 years old. Some are having problems with unbalanced loads and go into &quot;suds&quot; and shuts down during the last 5 minute spin. At 8 minutes, if it can't correct the unbalance by 5 minutes it will shut down. Could it be worn loose belts that are over 10 years old? What is the proper belt tension?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_02_19_Num_26" class="header">Update (02/19/26)</h3></div>
<p>Sometimes the load won't come up to speed and sometimes won't drain, leaving water in the drum, so I have to put it in 6 08 then P06 to manually spin.</p>
<p>⟐ Answer edited 二月 20, 2026 at 1:48 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/941394/What+is+the+proper+belt+tension+on+a+MHN33PDCWW0</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/941394</guid>
<pubDate>Fri, 20 Feb 2026 01:48:55 -0700</pubDate>
</item>
</channel>
</rss>
