<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Countertop Ice Maker&quot;]]></title>
<link>https://zh.ifixit.com/Answers/Device/Countertop_Ice_Maker?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Countertop Ice Maker&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 13 Jul 2026 22:24:11 -0700</pubDate>
<item>
<title><![CDATA[Euhomy IM-06D: 电器不工作]]></title>
<description><![CDATA[<p>制冰机通了电，机器不工作</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/927756/%E7%94%B5%E5%99%A8%E4%B8%8D%E5%B7%A5%E4%BD%9C</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/927756</guid>
<pubDate>Mon, 24 Nov 2025 17:22:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Countertop Ice Maker: Frigidaire countertop icemaker won't take up water]]></title>
<description><![CDATA[<p>Ice maker had started making tiny pieces of ice, so I ran a cleaning cycle with commercial ice maker cleaning solution, and scrubbed the inlet with a toothbrush. I ran another cleaning cycle with clear water, drained it, and then refilled the reservoir with clean water. The machine won't take any water from the reservoir, either on the cleaning or icemaking cycles. It attempts to start the cycle, then stops, and the light to add water comes on. The water level remains at the fill line.</p>
<p>⟐ Commented 五月 15, 2025 at 0:18 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/861777/Frigidaire+countertop+icemaker+won&#039;t+take+up+water</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/861777</guid>
<pubDate>Thu, 15 May 2025 00:18:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Opal 2.0: Why does my opal stop making ice?]]></title>
<description><![CDATA[<p>After about 9 months of making great ice, my GE Opal is blowing warm air and no longer making ice.  I have cleaned out the back but no change.  Any help appreciated.</p>
<p>Thanks.</p>
<p>⟐ Answered 四月 09, 2025 at 6:41 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/811225/Why+does+my+opal+stop+making+ice</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/811225</guid>
<pubDate>Wed, 09 Apr 2025 06:41:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Countertop Ice Maker: Ice Machine Fan Does Not Run Properly]]></title>
<description><![CDATA[<p>My family's ice maker, a Frigidaire EFIC117-SSBLACK-CU, has run an extended service of, if I have this right, at least 5 years of frosty production. Recently, however, the machine has begun to malfunction in a few ways.</p>
<p>The first issue to come to light was the fact that the fan that the machine had come with had stopped working. The device uses a PY-1225H12S fan for internal cooling. I replaced this fan and got the machine to work again. At least, for a while.</p>
<p>I somehow managed to not take the leakage of water present within the machine more seriously. The ice maker has a tube, which I measured to be 1/8 in. inner diameter, 1/4 in. outer diameter, that is used to transport water from the bottom of the machine's water reservoir up to the cooling rods, which are used to create ice, of course. The newer fan that I had installed recently stopped working properly, just two months after its installation. The first fan had shut off entirely, causing the device to overheat, and the second one jolted to attempt to spin, but could not. Spinning the fan manually as the machine was powered on would give the fan a tiny jump, but the fan would blow incredibly weakly, still permitting the system to become extremely hot, as in the case of the first fan.</p>
<p>Upon yet another disassembly, I discovered that the tubing was ruptured at the end which deposits water in the freezing area of the ice maker. This is what I suspect caused the first fan to die. And, I also figured that the second fan stopped working properly due to the leakage from the tubing. So, I ordered more tubing online, as well as a third replacement fan. I bought the incorrect tube size as of now, which brings me to not being able to cover that fix.</p>
<p>But even when wrapping paper towels around the tube where the leak occurs, and after having installed the third fan, I found that this third fan has the exact same problem as the second fan: the fan jolts and, with a start, moves a little, but not nearly enough to maintain a low temperature for the ice machine.</p>
<p>At this point, being a relative novice in repairs, I am stumped as to what else could be the issue, as to why the fan is not moving properly. Any help to guide me in the right direction would be greatly appreciated. Thank you for getting this far.</p>
<p>(P.S.: I would upload pictures, but I keep getting infinite loading thumbnails on the images I upload. And if I try to view the images, access is denied...)</p>
<p>⟐ Commented 十二月 26, 2024 at 6:34 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/881334/Ice+Machine+Fan+Does+Not+Run+Properly</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/881334</guid>
<pubDate>Thu, 26 Dec 2024 06:34:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Euhomy IM-06D: My fan comes on then goes off then on]]></title>
<description><![CDATA[<p>My fan comes on then off then on</p>
<p>⟐ Answered 六月 06, 2026 at 10:51 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/958365/My+fan+comes+on+then+goes+off+then+on</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/958365</guid>
<pubDate>Sat, 06 Jun 2026 10:51:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Opal 2.0: Where can parts be found for this unit?]]></title>
<description><![CDATA[<p>I have tried GE directly, i have tried amazon, ive tried aliexpress, and ive tried just searching different search engines. i settled for ebay purchases and the gearbox i bought last week has failed already. any assistance would be appreciated</p>
<p>⟐ Marked as duplicate 四月 09, 2025 at 7:44 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/895384/Where+can+parts+be+found+for+this+unit</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/895384</guid>
<pubDate>Wed, 09 Apr 2025 07:44:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Countertop Ice Maker: Where to find parts for Antarctic-Star model HZB12/C]]></title>
<description><![CDATA[<p>Looking for parts to my Antartic-Star ice maker, model HZB-12/C</p>
<p>⟐ Commented 八月 22, 2024 at 20:29 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/834292/Where+to+find+parts+for+Antarctic-Star+model+HZB12-C</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/834292</guid>
<pubDate>Thu, 22 Aug 2024 20:29:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Insignia Ice Maker NS-IMP26SS7: Ice bucket Basket Replacement]]></title>
<description><![CDATA[<p>Where can I find or order a replacement ice tray/ basket?My handle snapped.</p>
<p>⟐ Answered 六月 06, 2024 at 8:40 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/725486/Ice+bucket+Basket+Replacement</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/725486</guid>
<pubDate>Thu, 06 Jun 2024 08:40:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Insignia Ice Maker NS-IMP26SS7: ice maker not working]]></title>
<description><![CDATA[<p>Starting with machine off, I fill up to water line, turn on the ice maker, the fan is blowing, dumps one load of cubes after a few minutes, fan turns back on, Fan turns off, comes back on, turns off comes back on,  started to freeze 2nd batch but tries to release 2nd batch before it’s done. Starts over.</p>
<p>⟐ Answered 十月 04, 2022 at 13:01 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/587241/ice+maker+not+working</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/587241</guid>
<pubDate>Tue, 04 Oct 2022 13:01:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Countertop Ice Maker: icemaker blew smokey looking stuff out when I started it back making i]]></title>
<description><![CDATA[<p>I haven't let it make ice in about a month because I didn't need the ice.  I turned it back on tonight and it blew smokey stuf at me and smelled bad. Do you thinkI burned the motor up on the ice maker.  I stopped it from making ice again until I can get someone to look at it.</p>
<p>⟐ Answered 四月 11, 2017 at 1:29 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/388244/icemaker+blew+smokey+looking+stuff+out+when+I+started+it+back+making+i</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/388244</guid>
<pubDate>Tue, 11 Apr 2017 01:29:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Countertop Ice Maker: How to remove the cover over the f]]></title>
<description><![CDATA[<p>how to remove the cover over the fan, so I can get dust off of fan/</p>
<p>⟐ Commented 二月 21, 2026 at 11:10 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/941656/How+to+remove+the+cover+over+the+f</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/941656</guid>
<pubDate>Sat, 21 Feb 2026 11:10:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Euhomy IM-06D: do you have a schematic for IM-06D ice maker.]]></title>
<description><![CDATA[<p>Do you have a  schematic for a IM-06D Ice maker. mine is not powering up.</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/940603/do+you+have+a+schematic+for+IM-06D+ice+maker.</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/940603</guid>
<pubDate>Fri, 13 Feb 2026 21:05:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE XPIOX3SCSS Opal 2.0: How do I replace auger bushing]]></title>
<description><![CDATA[<p>How do i replace auger bushing</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/940479/How+do+I+replace+auger+bushing</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/940479</guid>
<pubDate>Thu, 12 Feb 2026 18:37:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Insignia Ice Maker NS-IMP26SS7: Why do the elements in my ice machine not get cold?]]></title>
<description><![CDATA[<p>I have a new ice machine It won't make ice because the element don't get cool</p>
<p>⟐ Answered 十一月 06, 2025 at 14:36 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/815982/Why+do+the+elements+in+my+ice+machine+not+get+cold</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/815982</guid>
<pubDate>Thu, 06 Nov 2025 14:36:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Euhomy IM-06D: صوت الصفاره التحذير مزعجه جدا]]></title>
<description><![CDATA[<p>كيف ممكن فصل الصوت</p>
<p>The warning beep is very annoying.</p>
<p>How can I turn off the beep?</p>
<p>⟐ Edited 九月 28, 2025 at 20:59 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/919500/%D8%B5%D9%88%D8%AA+%D8%A7%D9%84%D8%B5%D9%81%D8%A7%D8%B1%D9%87+%D8%A7%D9%84%D8%AA%D8%AD%D8%B0%D9%8A%D8%B1+%D9%85%D8%B2%D8%B9%D8%AC%D9%87+%D8%AC%D8%AF%D8%A7</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/919500</guid>
<pubDate>Sun, 28 Sep 2025 20:59:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Countertop Ice Maker: My add water light comes on and won't fill tray]]></title>
<description><![CDATA[<p>Sensor keeps saying add water</p>
<p>⟐ Commented 六月 04, 2025 at 18:40 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/902604/My+add+water+light+comes+on+and+won&#039;t+fill+tray</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/902604</guid>
<pubDate>Wed, 04 Jun 2025 18:40:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Countertop Ice Maker: Avanti IM1213SIS How do I take a part to clean]]></title>
<description><![CDATA[<p>How to clean the <strong><em>Avanti IM1213SIS</em></strong> machine How to clean the machine?</p>
<p>⟐ Edited 七月 07, 2024 at 17:15 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/858357/Avanti+IM1213SIS+How+do+I+take+a+part+to+clean</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/858357</guid>
<pubDate>Sun, 07 Jul 2024 17:15:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Countertop Ice Maker: Ice machine makes one batch of ice then stops with flashing triangle]]></title>
<description><![CDATA[<p>I have a Jost ice maker, model:  ZB-15P.  Sometimes it starts normally, makes one batch of ice and then stops with a flashing triangle with an exclamation inside.  Sometimes the triangle is there on startup.</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/828204/Ice+machine+makes+one+batch+of+ice+then+stops+with+flashing+triangle</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/828204</guid>
<pubDate>Wed, 13 Dec 2023 01:39:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Countertop Ice Maker: Ice maker showing spanner sign]]></title>
<description><![CDATA[<p>So my ice maker switches on then spanner sign shows up and it starts beeping ,but then again some days it'll work but lately mostly it won't,so annoying</p>
<p>Help plz</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_04_19_Num_23" class="header">Update (04/19/23)</h3></div>
<p>Js zbj a...pavo icemaker</p>
<p>⟐ Edited by author 四月 20, 2023 at 6:23 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/781813/Ice+maker+showing+spanner+sign</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/781813</guid>
<pubDate>Thu, 20 Apr 2023 06:23:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[Insignia Ice Maker NS-IMP26SS7: Problem with my ice maker]]></title>
<description><![CDATA[<p>When the water out to the ice maker and the water out on the water dispenser at the same time, and the same problem when I dispense the water from the water dispenser and the water pour out to the ice maker at the same time too.</p>
<p>⟐ Edited 三月 16, 2022 at 6:26 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/725429/Problem+with+my+ice+maker</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/725429</guid>
<pubDate>Wed, 16 Mar 2022 06:26:28 -0700</pubDate>
</item>
</channel>
</rss>
