<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Angle Grinder&quot;]]></title>
<link>https://zh.ifixit.com/Answers/Device/Angle_Grinder/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Angle Grinder&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 04 Sep 2026 07:27:42 -0700</pubDate>
<item>
<title><![CDATA[Makita Angle Grinder XAG04 2017: 机器通电后不转动]]></title>
<description><![CDATA[<p>感觉系电脑问题，机器通电后不能转动</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/968304/%E6%9C%BA%E5%99%A8%E9%80%9A%E7%94%B5%E5%90%8E%E4%B8%8D%E8%BD%AC%E5%8A%A8</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/968304</guid>
<pubDate>Sat, 15 Aug 2026 19:20:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[DeWalt D28110: Why is my grinder spinning so slowly?]]></title>
<description><![CDATA[<p>The power source/outlet that I am using works fine, but my tool is not spinning as fast as it should.</p>
<p>⟐ Commented 八月 29, 2026 at 11:10 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/213436/Why+is+my+grinder+spinning+so+slowly</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/213436</guid>
<pubDate>Sat, 29 Aug 2026 11:10:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Hitachi Angle Grinder G 12SS 2016: It just didn't go on after there was smoke]]></title>
<description><![CDATA[<p>It just smoked</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/956185/It+just+didn&#039;t+go+on+after+there+was+smoke</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/956185</guid>
<pubDate>Thu, 21 May 2026 18:17:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bosch Angle Grinder 601752060 2002: Unlocking the disc when tightly locked]]></title>
<description><![CDATA[<div class="wiki-note" data-note-type="important"><div class="wiki-note-label"><svg class="fill-current" width="16" height="16" aria-hidden="true" focusable="false" ><use href="/_next/charge/icons/next/duotone/solid/message-exclamation.svg?v=3#message-exclamation" /></svg>重要</div><div class="wiki-note-body"><p>What is the solution when the disc tightly locks itself and can't open up with it's normal key?</p></div></div>]]></description>
<link>https://zh.ifixit.com/Answers/View/953429/Unlocking+the+disc+when+tightly+locked</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/953429</guid>
<pubDate>Mon, 04 May 2026 12:39:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Other Brand Angle Grinder: Lead shift ,Rewinding 24 bar 12 slot armature]]></title>
<description><![CDATA[<p>I am rewinding an armature for an old-model metal-bodied Chinese mini angle grinder (approx. 700W-850W, 11,000-12,000 RPM).</p>
<p>Technical Specs:</p>
<p>- Core: 12 slots, 24 commutator bars.</p>
<p>- Dimensions: Core length 55mm, diameter 3.2cm.</p>
<p>- Wire: 32 AWG (0.20mm).</p>
<p>- Winding: Factory was 22 turns/coil (88 wires/slot total), but I plan to use 23 turns/coil (92 wires/slot) to improve torque and heat management.</p>
<p>- Pitch: 1 to 6.</p>
<p>- Progression: Retrogressive (1 -&gt; 24 -&gt; 23).</p>
<p>- Brushes: Positioned 90 degrees from the stator coils.</p>
<p>- Potting: Using two-part submersible pump epoxy (thinned with heat) in a vertical gravity-pour method.</p>
<p>The specific question is about the Lead Shift:</p>
<p>Because I am adding an extra turn (23 instead of 22) and the brushes are at 90 degrees, which lead shift is best to handle the high RPM and field twist?</p>
<p>1. Zero Shift (Bar 1 directly in center of Slot 1).</p>
<p>2. 7.5 Degree Shift (Mica directly in center of Slot 1).</p>
<p>3. 15 Degree Shift (Bar 24, one bar left, in center of Slot 1).</p>
<p>I am leaning toward the 7.5° (Mica Center) shift as a balance, but I'm worried about &quot;fire-ringing&quot; at 11,000 RPM. Has anyone done this specific 23-turn mod on these 12/24 armatures?</p>
<p>By ibot guess, the magnetic shift will ne around 18degree. I can't retrieve any original data of lead shift but from one saved coil, i get continuity from bar24 and 23, assuming first bar in center of slot is bar 1 and winding is retrogressive, connections moving left.</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/950662/Lead+shift+,Rewinding+24+bar+12+slot+armature</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/950662</guid>
<pubDate>Thu, 16 Apr 2026 05:30:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bosch Angle Grinder 1380SLIM 2011: Why does my grinder not work sometimes wen I power it on]]></title>
<description><![CDATA[<p>Sometimes grinder does not switch on wen I power it on</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/949666/Why+does+my+grinder+not+work+sometimes+wen+I+power+it+on</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/949666</guid>
<pubDate>Fri, 10 Apr 2026 12:38:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Other Brand Angle Grinder: How can I reduce the rpm of my grinder?]]></title>
<description><![CDATA[<p>How can I reduce the rpm of my grinder?</p>
<p>⟐ Commented 三月 24, 2026 at 1:58 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/943633/How+can+I+reduce+the+rpm+of+my+grinder</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/943633</guid>
<pubDate>Tue, 24 Mar 2026 01:58:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bosch Angle Grinder 1380SLIM 2011: Why my grinder not power]]></title>
<description><![CDATA[<p>why my grinder not power</p>
<p>⟐ Answered 三月 07, 2026 at 5:18 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/943664/Why+my+grinder+not+power</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/943664</guid>
<pubDate>Sat, 07 Mar 2026 05:18:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Die Grinder 9067L 2010: Why does my angle grinder doesnot work after chaincing the brushes]]></title>
<description><![CDATA[<p>Why does my angle grinder doesnot work after chaincing the brushes</p>
<p>⟐ Commented 三月 05, 2026 at 16:48 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/943398/Why+does+my+angle+grinder+doesnot+work+after+chaincing+the+brushes</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/943398</guid>
<pubDate>Thu, 05 Mar 2026 16:48:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bosch Angle Grinder: Bosch 10-125 c angle grinder. What bevel gear set I can use.]]></title>
<description><![CDATA[<p>I need data of bevel gear set like dimensions of crown wheel and pinion i can use for that model</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/941916/Bosch+10-125+c+angle+grinder.+What+bevel+gear+set+I+can+use.</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/941916</guid>
<pubDate>Mon, 23 Feb 2026 14:41:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Angle Grinder: Why the rotor spins but the blade doesn’t]]></title>
<description><![CDATA[<p>The rotor moves freely forward/backward instead of being fixed.</p>
<p>Blade doesn’t rotate or rotates very slowly.</p>
<p>⟐ Edited by author 二月 04, 2026 at 5:31 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/938678/Why+the+rotor+spins+but+the+blade+doesn%E2%80%99t</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/938678</guid>
<pubDate>Wed, 04 Feb 2026 05:31:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dewalt Electric Handheld D28402  TYPE 1 2005: Why does my grinder not want to turn when I push the paddle?]]></title>
<description><![CDATA[<p>When I push the paddle on the grinder it tries to turn on and stops in a second. I have to unplug it a couple of times for it to finally start working</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/938658/Why+does+my+grinder+not+want+to+turn+when+I+push+the+paddle</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/938658</guid>
<pubDate>Sat, 31 Jan 2026 15:49:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Die Grinder 9554NB 2010: no function and overheating]]></title>
<description><![CDATA[<p>my ginder is not functioning and overheating, how to fix this?</p>
<p>⟐ Answer edited 一月 04, 2026 at 9:02 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/933846/no+function+and+overheating</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/933846</guid>
<pubDate>Sun, 04 Jan 2026 09:02:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Milwaukee Angle Grinder 614230  H40A 2017: side handle thread size]]></title>
<description><![CDATA[<p>what is the side handle thread size ?</p>
<p>⟐ Answer accepted 十二月 15, 2025 at 1:57 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/905163/side+handle+thread+size</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/905163</guid>
<pubDate>Mon, 15 Dec 2025 01:57:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[DeWalt DWE4011: Any orbital sander with dust collection that is fixed with screws?]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I’m asking if there is any orbital sander or random orbital sander with dust collection that I can fix the sandpaper itself with screws from the middle?</p>
<p>I want to fix the sandpaper with screws because if there is any hard stuff (nails or so), the sandpaper flies out.</p>
<p>Regards,</p>
<p>⟐ Commented 十一月 25, 2025 at 7:43 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/680543/Any+orbital+sander+with+dust+collection+that+is+fixed+with+screws</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/680543</guid>
<pubDate>Tue, 25 Nov 2025 07:43:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Die Grinder 9524NB 2010: How to change carbon]]></title>
<description><![CDATA[<p>How to change carbon</p>
<p>⟐ Answered 十一月 09, 2025 at 19:24 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/925561/How+to+change+carbon</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/925561</guid>
<pubDate>Sun, 09 Nov 2025 19:24:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dewalt Electric Handheld D28110  TYPE 1 2005: I’m not able to route the 110 volt]]></title>
<description><![CDATA[<p>I replaced brushes and now the 110v  incoming power clamp doesn’t fit around the start switch. I’m missing something</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/921246/I%E2%80%99m+not+able+to+route+the+110+volt</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/921246</guid>
<pubDate>Fri, 10 Oct 2025 07:24:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bosch Angle Grinder AG50125PD 2017: Seems like my angle grinder is just dead it won't switch on]]></title>
<description><![CDATA[<p>My grinder won't switch on the power cord seems to be fine but i can't get it to work please help</p>
<p>⟐ Answer edited 十二月 09, 2025 at 5:59 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/916934/Seems+like+my+angle+grinder+is+just+dead+it+won&#039;t+switch+on</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/916934</guid>
<pubDate>Tue, 09 Dec 2025 05:59:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Mini Grinder 9564PC: Why is the roter winding sparking with brushes on the lamellas]]></title>
<description><![CDATA[<p>I cleaned the space between the lamella and it sparks nonstop when energized.</p>
<p>⟐ Answer edited 七月 28, 2025 at 6:24 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/909392/Why+is+the+roter+winding+sparking+with+brushes+on+the+lamellas</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/909392</guid>
<pubDate>Mon, 28 Jul 2025 06:24:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Milwaukee Angle Grinder: Why is Milwaukee heavy duty grinder 6098 cutting off]]></title>
<description><![CDATA[<p>Brushes are in great shape but are flat after cleaning with Emory paper. There's sparking at brushes when it runs briefly but cuts off. Have constant voltage to brush when I press trigger. Any help would be appreciated</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/snBmDPOv6AS62uo2.standard" width="169" height="225" class="hasMenu hasLarge" alt="图片" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/snBmDPOv6AS62uo2.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="qpkW5BK3DjEJyMNl" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/WE1MWLwvbNPvBH1B.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/qpkW5BK3DjEJyMNl_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="LJmkmewrM1oIH54N" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/fPjSRFvAaXQ1A2iI.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/LJmkmewrM1oIH54N_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="nNMAEEFUOxkgkWKt" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/oBGFFUJX1tLPFOex.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/nNMAEEFUOxkgkWKt_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="HhcKHOkVXaqVZUMN" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/sDYf65Z2cuGQMMkm.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/HhcKHOkVXaqVZUMN_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/QIITgHaieSyb13lK.standard" width="169" height="225" class="hasMenu hasLarge" alt="图片" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/QIITgHaieSyb13lK.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented 七月 15, 2025 at 23:14 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/907188/Why+is+Milwaukee+heavy+duty+grinder+6098+cutting+off</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/907188</guid>
<pubDate>Tue, 15 Jul 2025 23:14:49 -0700</pubDate>
</item>
</channel>
</rss>
