<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Air Compressor&quot;]]></title>
<link>https://zh.ifixit.com/Answers/Device/Air_Compressor/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Air Compressor&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 26 Aug 2026 02:20:29 -0700</pubDate>
<item>
<title><![CDATA[Dewalt Air Compressors DWFP55126 2016: Compressor stays at max pressure]]></title>
<description><![CDATA[<p>My DeWalt compressor regulator is inoperable and stays at max pressure. How do I replace the regulator?</p>
<p>⟐ Answered 八月 10, 2026 at 16:57 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/967554/Compressor+stays+at+max+pressure</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/967554</guid>
<pubDate>Mon, 10 Aug 2026 16:57:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 919152145 2017: What type of screwdriver needed to remove the Schroed]]></title>
<description><![CDATA[<p>Tools needed to remove the Schroed</p>
<p>⟐ Answer edited 七月 29, 2026 at 8:00 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/965798/What+type+of+screwdriver+needed+to+remove+the+Schroed</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/965798</guid>
<pubDate>Wed, 29 Jul 2026 08:00:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Campbell Hausfeld Air Compressor VT619600AJ 2014: How do I remove plastic belt housing?]]></title>
<description><![CDATA[<p>How do I remove plastic belt housing?</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/959394/How+do+I+remove+plastic+belt+housing</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/959394</guid>
<pubDate>Fri, 12 Jun 2026 10:44:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Air Compressor: How to set a switch one a 5 horse air compressor with a magnet switch]]></title>
<description><![CDATA[<p>How to set a magnet switch on a air compressor</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/959250/How+to+set+a+switch+one+a+5+horse+air+compressor+with+a+magnet+switch</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/959250</guid>
<pubDate>Thu, 11 Jun 2026 08:07:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Car Inflator: How I bypass battery supply and run on car power socket]]></title>
<description><![CDATA[<p>I have a portronics Portable Car Inflator. Which was run on Battery. But some of ics or other things are not working on PCB. So i decided to run this inflator direct from 12v dc car power socket. Please suggest me how to bypass battery supply</p>
<p>⟐ Commented 六月 03, 2026 at 19:17 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/958041/How+I+bypass+battery+supply+and+run+on+car+power+socket</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/958041</guid>
<pubDate>Wed, 03 Jun 2026 19:17:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Husky Air Compressor 2G110DPNG  BLACK 2011: Thumb connector replacement part]]></title>
<description><![CDATA[<p>I need a new thumb connector on my compressor, will I need a new hose as well for that replacement?</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/957838/Thumb+connector+replacement+part</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/957838</guid>
<pubDate>Mon, 01 Jun 2026 16:39:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Hitachi Air Compressor EC2510E 2007: Hitachi EC2510E stalls motor when pump reengages]]></title>
<description><![CDATA[<p>Compressor starts good. It builds pressure and reduces pump and motor, but when pump reengages, it stalls the motor. I have replaced unloader valve.</p>
<p>⟐ Commented 五月 22, 2026 at 18:56 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/956292/Hitachi+EC2510E+stalls+motor+when+pump+reengages</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/956292</guid>
<pubDate>Fri, 22 May 2026 18:56:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Air Compressor: Open Amp Sensor error in GD compressor]]></title>
<description><![CDATA[<p>Hi<br /><br />I am working on Gardner Denver Compressor model Electra Saver.<br />I recently came across an error message Shutdown 'Open Amp Sensor'</p>
<p><br />This error message popped up within few minutes upon turning on. There is a light on the Compressor motor as seen in above pic, don't know what it means. The motor doesn't get hot.<br /></p>
<p>After pressing Reset &amp; then Constant run, the compressor runs, in most of the cases - all day. But sometimes it stops after running for few hours with above error message.<br /></p>
<p>I tried to look thru the manual but couldn't find above Error message.<br />Any thoughts what this error is for &amp; how to fix it?<br /><br />Thanks</p>
<p>⟐ Commented 五月 06, 2026 at 21:33 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/946941/Open+Amp+Sensor+error+in+GD+compressor</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/946941</guid>
<pubDate>Wed, 06 May 2026 21:33:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Husky Air Compressor H2G3TK  2009 2009: Where can I get reed valve replacement]]></title>
<description><![CDATA[<p>Reed valve replacement</p>
<p>⟐ Answered 五月 02, 2026 at 18:29 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/953153/Where+can+I+get+reed+valve+replacement</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/953153</guid>
<pubDate>Sat, 02 May 2026 18:29:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Husky Air Compressor H2G3TK  2009 2009: Compressor doesn't start?]]></title>
<description><![CDATA[<p>Give the replacement motor part number which isn't listed. But the motor is shown. <strong>Thanks 👍 😊</strong></p>
<p>⟐ Commented 五月 02, 2026 at 18:28 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/931143/Compressor+doesn&#039;t+start</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/931143</guid>
<pubDate>Sat, 02 May 2026 18:28:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Porter Cable Air Compressor C2002  TYPE 9 2014: Part #for the pressure switch]]></title>
<description><![CDATA[<p>Part number for pressure switch</p>
<p>⟐ Answered 五月 02, 2026 at 17:48 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/953179/Part+%23for+the+pressure+switch</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/953179</guid>
<pubDate>Sat, 02 May 2026 17:48:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Hitachi Air Compressor EC510 2012: My compressor will not gain more than 45 psi and keeps running.]]></title>
<description><![CDATA[<p>My compressor will not gain more than 45 psi and keeps running Any thoughts</p>
<p>⟐ Commented 四月 30, 2026 at 17:49 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/952626/My+compressor+will+not+gain+more+than+45+psi+and+keeps+running.</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/952626</guid>
<pubDate>Thu, 30 Apr 2026 17:49:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Husky Air Compressor 0300813A 2017: How do I order replacement off on switch number 17 on diagram]]></title>
<description><![CDATA[<p>Need replacement parts</p>
<p>⟐ Answered 四月 28, 2026 at 19:05 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/952560/How+do+I+order+replacement+off+on+switch+number+17+on+diagram</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/952560</guid>
<pubDate>Tue, 28 Apr 2026 19:05:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid Air Compressor OF45200SS 2019: How do you reconnect or replace the air line going to the tanks?]]></title>
<description><![CDATA[<p>How do you disassemble the top of compressor to get to the air lines that go to the tanks to repair or replace it?</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/952412/How+do+you+reconnect+or+replace+the+air+line+going+to+the+tanks</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/952412</guid>
<pubDate>Mon, 27 Apr 2026 23:42:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dewalt Air Compressor D55168  TYPE 9 2017: The Compressor is not building pressure gauge show 0]]></title>
<description><![CDATA[<p>Gauges are on 0 checked the valve plate change it for another ( used) the pressure is the same 0</p>
<p>⟐ Answered 四月 14, 2026 at 11:02 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/950355/The+Compressor+is+not+building+pressure+gauge+show+0</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/950355</guid>
<pubDate>Tue, 14 Apr 2026 11:02:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Husky Air Compressor H1504ST2 2009: The tank shows pressure, but no pressure at the outlet.]]></title>
<description><![CDATA[<p>No pressure at ourlet</p>
<p>⟐ Commented 四月 04, 2026 at 21:44 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/948637/The+tank+shows+pressure,+but+no+pressure+at+the+outlet.</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/948637</guid>
<pubDate>Sat, 04 Apr 2026 21:44:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dewalt Air Compressor D55155  TYPE 1 2011: hums when I turn it on.]]></title>
<description><![CDATA[<p>Hums and motor turns very easy but very slow. incoming voltage is 124v. after I turn switch on, voltage across both sets of contacts on contactor drops to aprox 40v.</p>
<p>⟐ Commented 三月 20, 2026 at 18:02 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/946025/hums+when+I+turn+it+on.</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/946025</guid>
<pubDate>Fri, 20 Mar 2026 18:02:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 92115215 2012: craftsman model 921 152150 pancake air compressor]]></title>
<description><![CDATA[<p>how do i remove the power switch?</p>
<p>⟐ Commented 二月 19, 2026 at 17:48 GMT-7</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/925235/craftsman+model+921+152150+pancake+air+compressor</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/925235</guid>
<pubDate>Thu, 19 Feb 2026 17:48:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Air Compressor: My electric compressor wont start]]></title>
<description><![CDATA[<p>I checked switch and it had continuity. I think its a part that power goes into only has 2 leads dont know name but i checked it with a meter it had continuity with black to white but i tested it with other set of black and white and got no continuity Its a blue hawk 8 gallon</p>]]></description>
<link>https://zh.ifixit.com/Answers/View/939345/My+electric+compressor+wont+start</link>
<guid isPermaLink="false" >https://zh.ifixit.com/Answers/View/939345</guid>
<pubDate>Wed, 04 Feb 2026 20:15:15 -0700</pubDate>
</item>
</channel>
</rss>
