跳转到主内容
GoPro Hero3+ Black Edition Front Face Plate Replacement
你所需要的
  1. GoPro Hero3+ Black Edition Front Face Plate Replacement, Front Face Plate: 步骤 1 中的图像 1,2 GoPro Hero3+ Black Edition Front Face Plate Replacement, Front Face Plate: 步骤 1 中的图像 2,2
    • Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
    • To avoid breaking or weakening the tabs on the face plate which hold it in place, alternate the sides from which you pry and check each tab before separating the plate from the body.
结论
To reassemble your device, press face plate back on with hands.
另外一个人完成了本指南。
Nathan Braham
于04/14/15注册
110 声望
撰写一个指南
团队
Cal Poly, Team 6-15, Maness Spring 2015 Cal Poly, Team 6-15, Maness Spring 2015 的会员
CPSU-MANESS-S15S6G15
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,647
