跳转到主内容
1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement
你所需要的
  1. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: 步骤 1 中的图像 1,3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: 步骤 1 中的图像 2,3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: 步骤 1 中的图像 3,3
    • Here is the Jeep GC. Removal of the headlamp is identical for both sides.
    • By opening the hood and looking straight down on the headlamp assembly, the 6mm hex head jack screw can be seen.
    • Use a 6mm socket and nut driver to remove the jack screw. 1/4 socket will not fit 9/32 does, but it is a bit sloppy
  2. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: 步骤 2 中的图像 1,3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: 步骤 2 中的图像 2,3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: 步骤 2 中的图像 3,3
    • Remove the long jack screw.
    • Grasp upper inboard and lower outboard corners of headlamp and forcefully pull headlamp outward.
    • Remove all bulb sockets from headlamp module. Separate headlamp from vehicle.
结论
6等其他人完成本指南。
oldturkey03
于09/29/10注册
782,216 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了537篇指南
4条评论
It’s a 7mm socket
Don Marcos - 回复
Not on mine. Just rechecked and it is a 6mm on my Jeep
oldturkey03 -
Thankful for simple instructions without any extra info or words ?
robinrogersk9 - 回复
I’m removing it to replace fan cooling module. I heard I can cut through to get to it without disassembling the grill bumper etc
robinrogersk9 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 37
总计 7,560
