跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的iPad Mini 3 Wi-Fi,请使用我们的维修手册
  1. iPad Mini 3 Wi-Fi Teardown, iPad Mini 3 Wi-Fi Teardown: 步骤 1 中的图像 1,1
    • Pint-sized tech means pint-sized specs! Inside the iPad Mini 3, we expect to find:
    • 7.9-inch (diagonal) LED-backlit Multi-Touch display with IPS technology
    • A7 chip with 64‑bit architecture + M7 motion coprocessor
    • 5 MP iSight camera + 1.2 MP FaceTime HD camera
    • Wi‑Fi (802.11a/​b/​g/​n) with dual channel (2.4GHz and 5GHz) and MIMO support + Bluetooth 4.0
    • 23.8 Wh rechargeable lithium-polymer battery
    • Three-axis gyro + accelerometer + ambient light sensor
  2. iPad Mini 3 Wi-Fi Teardown: 步骤 2 中的图像 1,2 iPad Mini 3 Wi-Fi Teardown: 步骤 2 中的图像 2,2
    • If you were wondering how to tell the iPad Mini Retina Display (aka iPad Mini 2) apart from the iPad Mini 3, we've got you covered:
    • The iPad Mini 3 now supports Touch ID, to be used in conjunction with  Pay.
    • Gold. So much gold. Gold everywhere.
    • Continuing the trend set by the iPad Air 2, the iPad Mini 3 sports the model number A1599.
  3. iPad Mini 3 Wi-Fi Teardown: 步骤 3 中的图像 1,3 iPad Mini 3 Wi-Fi Teardown: 步骤 3 中的图像 2,3 iPad Mini 3 Wi-Fi Teardown: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    iOpener
    $19.99
    购买
    • The iOpener has revolutionized the way we open up iPads.
    • A little heat is just the thing to soften up the adhesive securing the iPad's display.
    • We place our iOpener around the perimeter of the iPad Mini 3 and begin using our opening picks to separate the front panel from the rear case.
    • After a bit of work and patience, we achieve our goal.
  4. iPad Mini 3 Wi-Fi Teardown: 步骤 4 中的图像 1,3 iPad Mini 3 Wi-Fi Teardown: 步骤 4 中的图像 2,3 iPad Mini 3 Wi-Fi Teardown: 步骤 4 中的图像 3,3
    • As is often the case with updates that don't really change anything, nothing has really changed yet.
    • Unlike in the new iPad Air 2, the front panel glass and LCD are still separate components, individually replaceable.
    • Take a look, it's in a book...
    • With the LCD out, we find our first and only change in construction: Some absolutely terrific home button cabling. Wow. That wasn't last-minute at all.
    • Is that hot glue?
  5. iPad Mini 3 Wi-Fi Teardown: 步骤 5 中的图像 1,3 iPad Mini 3 Wi-Fi Teardown: 步骤 5 中的图像 2,3 iPad Mini 3 Wi-Fi Teardown: 步骤 5 中的图像 3,3
    • Yes—that is hot glue, holding the home button bracket to the front panel. Good luck transferring that to your replacement glass. (Which you're going to have to do, to keep the Touch ID functionality after a cracked screen repair.)
    • Looks like the cable is a bit of a nightmare all by itself.
    • Apple's system for implementing Touch ID seems to require launching about a year before it's ready. Remember the Touch ID cable in the iPhone 5s? And the much-improved placement in the iPhone 6?
    • No surprises here: Touch ID in the Mini is powered by an NXP Semiconductors 8416A1 Touch ID Sensor.
  6. iPad Mini 3 Wi-Fi Teardown: 步骤 6 中的图像 1,1
    • Logic board! Let's just get to it, shall we? Anything new?
    • Apple A7 APL0698 SoC
    • Within the A7 package we find SK Hynix H9CKNNN8KTARKR 1 GB LPDDR3 DRAM
    • SK Hynix H2JTDG8UD1BMR 16 GB NAND Flash
    • Universal Scientific Industrial 339S0213 Wi-Fi Module
    • Apple 343S00004-A1
    • NXP Semiconductors 65V10 NFC Controller
  7. iPad Mini 3 Wi-Fi Teardown: 步骤 7 中的图像 1,1
    • NXP Semiconductors LPC18A1 (Apple M7 Motion Co-Processor)
    • Apple (Cirrus Logic) 338S1213 Audio Codec
    • Apple 338S1199—likely a pair of audio amplifiers, similar to the Apple 338S1077 found in the previous iPad mini
    • Fairchild Semiconductor FDMC6676BZ and FDCM6683 MOSFETs
    • NXP 1610A1 Display Interface IC
  8. iPad Mini 3 Wi-Fi Teardown: 步骤 8 中的图像 1,2 iPad Mini 3 Wi-Fi Teardown: 步骤 8 中的图像 2,2
    • iPad Mini 3 Repairability: 2 out of 10 (10 is easiest to repair).
    • The LCD and glass are not fused together and can be replaced independently.
    • The battery is not soldered to the logic board or other components.
    • Copious amounts of adhesive hold many components in place—front glass, battery, front camera, back camera, ribbon cables—making repair extremely difficult.
    • The Lightning connector is soldered to the logic board, so don't bend its pins.
    • Removing the home button is now a much more difficult job. If you want to keep Touch ID functionality after a screen replacement, you'll have to transfer the home button to the new front panel.
Geoff Wacker
于09/30/13注册
90,075 声望
创作了89篇指南
10条评论
Is the digitizer the same as the iPad Mini 1/2?
npham54 - 回复
You can test the connectors are same.
Filip Pusca -
I've looked better at the circuit on BRD and can tell you that iPad Mini 3 have different circuit for touch screen connector, but iPad Mini 1 and iPad Mini 2 have same circuit.
Filip Pusca -
What is really important, to show there the glue is on the iPad, I don't see that the glue is all around the Display, only in the edges under the Home button an of cause over the camera, please show this better ! Thank You for sharing your DIY :-)
gorednet - 回复
Thank god there is nothing wrong with mine,in fact it still looks brand new,but i have these guides in case something happens
Daniel Gartin - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 70
总计 80,945
