跳转到主内容
iPhone 15 Pro Back Glass Replacement
你所需要的
  1. iPhone 15 Pro Back Glass Replacement, Prepare your iPhone for disassembly: 步骤 1 中的图像 1,2 iPhone 15 Pro Back Glass Replacement, Prepare your iPhone for disassembly: 步骤 1 中的图像 2,2
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
  2. iPhone 15 Pro Back Glass Replacement, Tape over any cracks: 步骤 2 中的图像 1,2 iPhone 15 Pro Back Glass Replacement, Tape over any cracks: 步骤 2 中的图像 2,2
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Pro Back Glass Replacement, Mark your opening picks: 步骤 3 中的图像 1,3 iPhone 15 Pro Back Glass Replacement, Mark your opening picks: 步骤 3 中的图像 2,3 iPhone 15 Pro Back Glass Replacement, Mark your opening picks: 步骤 3 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 15 Pro Back Glass Replacement, Remove the pentalobe screws: 步骤 4 中的图像 1,2 iPhone 15 Pro Back Glass Replacement, Remove the pentalobe screws: 步骤 4 中的图像 2,2
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
  5. iPhone 15 Pro Back Glass Replacement, Secure the screen: 步骤 5 中的图像 1,3 iPhone 15 Pro Back Glass Replacement, Secure the screen: 步骤 5 中的图像 2,3 iPhone 15 Pro Back Glass Replacement, Secure the screen: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Clamp
    $24.95
    购买
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open only the back glass, you need to secure the screen with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the screen to secure it.
  6. iPhone 15 Pro Back Glass Replacement, Secure an Anti-Clamp: 步骤 6 中的图像 1,3 iPhone 15 Pro Back Glass Replacement, Secure an Anti-Clamp: 步骤 6 中的图像 2,3 iPhone 15 Pro Back Glass Replacement, Secure an Anti-Clamp: 步骤 6 中的图像 3,3
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the back glass facing up, slide the arms over the right edge of your phone, with one suction cup on the back glass and the other on the screen. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 15 Pro Back Glass Replacement, Create a gap under the back glass: 步骤 7 中的图像 1,3 iPhone 15 Pro Back Glass Replacement, Create a gap under the back glass: 步骤 7 中的图像 2,3 iPhone 15 Pro Back Glass Replacement, Create a gap under the back glass: 步骤 7 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may use your hands to clean the suction cups and warm them up to help them stick.
  8. iPhone 15 Pro Back Glass Replacement, Insert an opening pick: 步骤 8 中的图像 1,2 iPhone 15 Pro Back Glass Replacement, Insert an opening pick: 步骤 8 中的图像 2,2
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the back glass and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti-Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  9. iPhone 15 Pro Back Glass Replacement, Heat the bottom edge: 步骤 9 中的图像 1,1
  10. iPhone 15 Pro Back Glass Replacement, Insert an opening pick: 步骤 10 中的图像 1,3 iPhone 15 Pro Back Glass Replacement, Insert an opening pick: 步骤 10 中的图像 2,3 iPhone 15 Pro Back Glass Replacement, Insert an opening pick: 步骤 10 中的图像 3,3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  11. iPhone 15 Pro Back Glass Replacement, Back glass information: 步骤 11 中的图像 1,1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the wireless charging cable near the volume buttons.
  12. iPhone 15 Pro Back Glass Replacement, Separate the bottom edge adhesive: 步骤 12 中的图像 1,3 iPhone 15 Pro Back Glass Replacement, Separate the bottom edge adhesive: 步骤 12 中的图像 2,3 iPhone 15 Pro Back Glass Replacement, Separate the bottom edge adhesive: 步骤 12 中的图像 3,3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  13. iPhone 15 Pro Back Glass Replacement, Heat the left edge: 步骤 13 中的图像 1,1
    • Heat the left edge of the back glass until it's hot to the touch.
  14. iPhone 15 Pro Back Glass Replacement, Separate the left edge adhesive: 步骤 14 中的图像 1,2 iPhone 15 Pro Back Glass Replacement, Separate the left edge adhesive: 步骤 14 中的图像 2,2
    • Don't insert your pick deeper than 5 mm along the left edge.
    • Insert a second opening pick to the left of the first one.
    • Slide this pick to the top left corner of the back glass to separate the left edge adhesive.
    • Leave this pick inserted to prevent the adhesive from resealing.
  15. iPhone 15 Pro Back Glass Replacement, Heat the top edge: 步骤 15 中的图像 1,1
    • Heat the top edge of the back glass until it's hot to the touch.
  16. iPhone 15 Pro Back Glass Replacement, Separate the top edge adhesive: 步骤 16 中的图像 1,3 iPhone 15 Pro Back Glass Replacement, Separate the top edge adhesive: 步骤 16 中的图像 2,3 iPhone 15 Pro Back Glass Replacement, Separate the top edge adhesive: 步骤 16 中的图像 3,3
    • Don't insert your pick deeper than 5 mm along the top edge.
    • Insert a third opening pick in the top left corner of the back glass.
    • Slide your pick to the top right corner to separate the top edge adhesive.
    • If the top edge of the back glass doesn't separate, the top clips may be stuck. Use the flat end of a spudger to press the clips inward until they release.
  17. iPhone 15 Pro Back Glass Replacement, Separate the top right corner adhesive: 步骤 17 中的图像 1,3 iPhone 15 Pro Back Glass Replacement, Separate the top right corner adhesive: 步骤 17 中的图像 2,3 iPhone 15 Pro Back Glass Replacement, Separate the top right corner adhesive: 步骤 17 中的图像 3,3
    • Don't slide your pick past the volume up button to avoid slicing the wireless charging cable.
    • Rotate your pick around the top right corner of the back glass.
    • Slide your pick to the volume up button.
    • Leave this pick in place to prevent the adhesive from resealing.
  18. iPhone 15 Pro Back Glass Replacement, Heat the right edge: 步骤 18 中的图像 1,1
    • Heat the right edge of the back glass until it's hot to the touch.
  19. iPhone 15 Pro Back Glass Replacement, Separate the right edge adhesive: 步骤 19 中的图像 1,3 iPhone 15 Pro Back Glass Replacement, Separate the right edge adhesive: 步骤 19 中的图像 2,3 iPhone 15 Pro Back Glass Replacement, Separate the right edge adhesive: 步骤 19 中的图像 3,3
    • Don't slide your pick past the volume down button to avoid slicing the wireless charging cable.
    • Insert a fourth opening pick at the bottom edge of the back glass.
    • Rotate your pick around the bottom right corner of the back glass.
    • Slide your pick to the volume down button.
  20. iPhone 15 Pro Back Glass Replacement, Swing open the back glass: 步骤 20 中的图像 1,3 iPhone 15 Pro Back Glass Replacement, Swing open the back glass: 步骤 20 中的图像 2,3 iPhone 15 Pro Back Glass Replacement, Swing open the back glass: 步骤 20 中的图像 3,3
    • Gently swing open the back glass over the right edge of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a box or similar object so it doesn't strain the cable.
  21. iPhone 15 Pro Back Glass Replacement, Remove the wireless charging connector cover: 步骤 21 中的图像 1,3 iPhone 15 Pro Back Glass Replacement, Remove the wireless charging connector cover: 步骤 21 中的图像 2,3 iPhone 15 Pro Back Glass Replacement, Remove the wireless charging connector cover: 步骤 21 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a tri-point Y000 driver to remove the 1.0 mm screw securing the wireless charging connector cover.
    • Use tweezers to slide the cover out of its slot on the logic board and remove it.
  22. iPhone 15 Pro Back Glass Replacement, Disconnect the wireless charging coil: 步骤 22 中的图像 1,2 iPhone 15 Pro Back Glass Replacement, Disconnect the wireless charging coil: 步骤 22 中的图像 2,2
    • Use the tip of an opening pick to pry up and disconnect the wireless charging coil press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
  23. iPhone 15 Pro Back Glass Replacement, Remove the back glass: 步骤 23 中的图像 1,2 iPhone 15 Pro Back Glass Replacement, Remove the back glass: 步骤 23 中的图像 2,2
    • Remove the back glass.
    • During reassembly, use this guide to reapply adhesive and install your back glass.
结论
To reassemble your iPhone, follow this guide to apply adhesive and install your back glass.
2等其他人完成本指南。
Spencer Day
于09/14/22注册
55,213 声望
创作了408篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,442篇指南
5条评论
Dont understand why Apple used all-glueed back glass earlier.
Oleksandr Ivanov - 回复
Is the flash camera still tied to the motherboard?
Duck - 回复
The flash unit is glued to the back glass, along with the wireless charging coil. The rear cameras are accessible by entering through the screen.
Clay Eickemeyer -
Wo bekomme ich denn eine solche Rückseite her?
Kim Riedel - 回复
does ifixit sell parts for this?
Meow Purr - 回复
添加评论
浏览统计数据:
过去 24 小时: 99
过去 7 天: 512
过去 30 天: 2,460
总计 10,824
