简介
如果你的 iPhone 13 Pro Max 屏幕破裂、触摸无响应或在手机开机时不显示图片,请使用本指南使用新屏幕(也称为显示组件)将 iPhone 恢复到正常工作状态。
注意: True Tone 和自动亮度功能在更换屏幕后被禁用,即使使用原装 Apple 屏幕也是如此。 Face ID 也会被禁用,除非 iPhone 运行的是 iOS 15.2 或更新版本。
你所需要的
将蓝色手柄拉向铰链以解除开启模式。
将反向钳手臂滑过 iPhone 的左边缘或右边缘。
将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
向下推吸盘以将吸力施加到所需区域。
使用 Y000 螺丝刀从前传感器接口盖上卸下两颗 1.1 毫米螺丝。
使用十字螺丝刀从前传感器接口盖上卸下剩余的两颗螺丝:
一颗 1.5 毫米螺丝
一颗 1.8 毫米螺丝
将你的新更换零件与原始零件进行比较——你可能需要在安装前转移剩余的组件或去除新零件的背胶。
要重新组装你的设备,请按逆序执行上述步骤。
将你的电子垃圾送到 R2 或 e-Stewards 认证的回收商。
32等其他人完成本指南。
由衷感谢以下译者:
96%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
8条评论
There is more to this repair than what you are showing. You aren’t showing us how and what to transfer off the old screen to the new one.
Screen Dr. - 回复
What components will need to be transferred over will depend on the replacement screen you receive. Some come with everything, some don't. I reference the parts iFixit sells when writing guides, and this guide will be updated if necessary once we have these screens in stock.
thanks for the article. I had a slightly different setup and your step 14 didn't address this and I tore one of the ribbon connectors that goes up tot the camera. I don't know what this is called so i don't know what to order. the ribbon that broke was the one disconnected in step 21. what is this and can it be replaced? thanks!
Hey. I changed my 13 pro max display, with the true tone and the auto brightness I also see that the display is not getting the maximum brightness level as supposed to. I see a big difference when I open the camera and switch between Video and Photo mode. Can it be fixed? Thank you!
