简介
请使用本指南来更换10.5寸iPad Pro的电池。
由于本指南某些步骤中电池可能仍然连接到主板上,请在尝试本指南之前将iPad保持通电状态,直到电池完全耗尽(iPad自动关闭)。如果意外刺穿已充电的锂离子电池,可能会导致起火甚至爆炸,请务必注意。
请准备足够多浓度超过90%的酒精,以帮助更轻松地移除电池并清除残留物。
如果您的电池已膨胀,请采取适当的预防措施。
你所需要的
加热iPad的左边约两分钟,或者直到它变得稍微烫手。
如有必要,重新加热iOpener几秒钟,直到它稍微烫手。注意不要过热iOpener,否则它可能会爆裂。
在iPad的左下角插入第二个撬片。
将第二个撬片沿屏幕面板的左侧划动,以分离下面的粘胶。
将第二个撬片留在iPad的左上角附近,以防止粘胶重新粘合。
比较您的新替换零件与原零件。在安装之前,您可能需要将剩余的部件转移到新零件上或去掉新零件上的粘胶背衬。
重新组装您的设备时,请按相反的顺序按照以下说明进行。
如果可能的话,在重新封闭平板电脑之前,请打开您的iPad并进行修复测试。
为了获得最佳性能,请在完成本指南后校准您新安装的电池:将其充电至100%,并继续充电至少2小时。然后使用您的设备,直到它因电量不足而关闭。最后,将其连续充电至100%。
将您的电子废物交给R2 or e-Stewards 认证的回收商妥善处理。
修复未如预期进行?查看我们的论坛以获取故障排除帮助。
47等其他人完成本指南。
由衷感谢以下译者:
88%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
12条评论
If you say the “the battery isolation method in this guide is outdated” then what is the correct way to isolate the battery?!?! The rest of the guide makes no mention of the correct/prefered method of isolating the battery.
How is it that the author took the time to update the guide with that message but failed to mention what should be done instead
Good point! We are currently still researching a more reliable alternative to the battery isolation procedure. As of now, the battery blocker method still works—it just has substantial dangers. This is especially true for iPad Pros, where the Logic Board is adhered to the frame. I’ve reworded the warnings to reflect this.
Hi can you advise please? In step 25 the SIM card tray flex cable is disconnected, no problem apart from i don’t have a SIM card tray flex cable in the A1701 that i’m repairing!! Urgent assistance required please. Regards R
You have the Wi-Fi model, which will look slightly different and have different procedures compared to the cellular model. You can skip the SIM flex cable step.
