跳转到主内容
Repairing Nintendo 64 Controller Joystick Replacement
你所需要的
  1. Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 步骤 1 中的图像 1,3 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 步骤 1 中的图像 2,3 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 步骤 1 中的图像 3,3
    • Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
    • Remove the 2 #00 Phillips screws from the expansion slot
    • Remove the rear housing and set aside.
  2. Repairing Nintendo 64 Controller Joystick Replacement: 步骤 2 中的图像 1,3 Repairing Nintendo 64 Controller Joystick Replacement: 步骤 2 中的图像 2,3 Repairing Nintendo 64 Controller Joystick Replacement: 步骤 2 中的图像 3,3
    • Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
    • Remove the 3 #00 Phillips screws holding the joystick assembly in place.
  3. Repairing Nintendo 64 Controller Joystick Replacement: 步骤 3 中的图像 1,3 Repairing Nintendo 64 Controller Joystick Replacement: 步骤 3 中的图像 2,3 Repairing Nintendo 64 Controller Joystick Replacement: 步骤 3 中的图像 3,3
    • Disconnect the joystick data cable and remove the old joystick.
    • To install your new joystick, simply follow these instructions in reverse.
结论
Test out your controller! It should be feeling like new.
33等其他人完成本指南。
Zillatron
于08/28/12注册
1,511 声望
撰写一个指南
2条评论
If you don't line up the z button accurately it can be tricky getting the case back on.
Rainer De Temple - 回复
I have a couple thumbstick replacements that do not have the connector. They are from Sodial, and I was wondering if there was a way that they can be easily connected.
derocher1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 49
过去 30 天: 231
总计 44,676
