简介
Oculus Quest 2(也名为Meta Quest 2)是由Facebook(原Oculus)开发的一款VR头显,是Quest系列的第二代产品。Quest2 可以作为一款独立VR主机使用,也可以通过USB电缆或Wi-Fi串流电脑画面。Quest 2还配备了高通XR2芯片与6GB内存,单眼分辨率为1823*1920。此外Quest 2 还有很多螺丝,一定要注意保管好它们。
你所需要的
四个 #0 十字螺丝, 将塑料部件固定在两侧的侧臂和扬声器上
移除两侧的 侧臂和扬声器 上的四个金属夹。
固定侧臂的塑料部件可以被移除或拧下,从而将侧臂从外壳上卸下。
117等其他人完成本指南。
由衷感谢以下译者:
45%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
79条评论
Thank you so much to me for making this guide. Helped me a lot!
It is worth emphasizing that this device has 2! WIFI antennas.
Anyone who wants to disconnect WIFI from their device must disconnect both.
Their connection to the motherboard, is right next to each other, but the right connection is immediately revealed while the left connection next to it is hidden under the black cover and requires a number of additional disassembly steps.
Alternatively, anyone who wants to disconnect WIFI from their device can disconnect the wires in the area where they connect to the antenna stickers on the right and left sides of the eyepieces of the glasses, thus saving all the disassembly of the front cover.
Thanks!! this really helped me, I have already customized mine with an official custom filter, but this will add an additional layer of Kashrus.
If you just need to replace a camera… it’s 14 screws. You need a T2 and a PH0 (not a P0…) Pretty easy once you get the front cover off and not covered here. It’s pretty easy to see what you do once you get in there though. Good luck!
PH0 and P0 are the same :)
Lylo -
Bravo pour ces informations. Un grand merci
