跳转到主内容
Motorola RAZR Maxx HD Screen Replacement
你所需要的
  1. Motorola RAZR Maxx HD Screen Replacement, Screen Removal: 步骤 1 中的图像 1,2 Motorola RAZR Maxx HD Screen Replacement, Screen Removal: 步骤 1 中的图像 2,2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Screen Replacement: 步骤 2 中的图像 1,2 Motorola RAZR Maxx HD Screen Replacement: 步骤 2 中的图像 2,2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Screen Replacement: 步骤 3 中的图像 1,2 Motorola RAZR Maxx HD Screen Replacement: 步骤 3 中的图像 2,2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Screen Replacement: 步骤 4 中的图像 1,2 Motorola RAZR Maxx HD Screen Replacement: 步骤 4 中的图像 2,2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Screen Replacement, Front-Facing Camera: 步骤 5 中的图像 1,1
    • On the back of the LCD display, release the yellow front-facing camera ribbon cable by gently lifting upward on the black retaining clip with the spudger.
  6. Motorola RAZR Maxx HD Screen Replacement: 步骤 6 中的图像 1,3 Motorola RAZR Maxx HD Screen Replacement: 步骤 6 中的图像 2,3 Motorola RAZR Maxx HD Screen Replacement: 步骤 6 中的图像 3,3
    • With a Torx T3 screwdriver, unscrew the two 2.0 mm screws on front-facing camera mounting bracket. Then lift to remove it.
  7. Motorola RAZR Maxx HD Screen Replacement: 步骤 7 中的图像 1,2 Motorola RAZR Maxx HD Screen Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the front-facing camera by lifting it from the LCD display frame.
  8. Motorola RAZR Maxx HD Screen Replacement, Earpiece Speaker: 步骤 8 中的图像 1,1
    • Insert the spudger between the speaker and retaining clip and gently pry upward to release the earpiece speaker.
  9. Motorola RAZR Maxx HD Screen Replacement: 步骤 9 中的图像 1,2 Motorola RAZR Maxx HD Screen Replacement: 步骤 9 中的图像 2,2
    • Using a spudger, gently pry up on the lower right edge of the black earpiece speaker ribbon cable, attached to the screen, to release it from the LCD display.
结论
8等其他人完成本指南。
Enrique
于02/01/15注册
371 声望
创作了2篇指南
团队
Cal Poly, Team 8-40, Amido Winter 2015 Cal Poly, Team 8-40, Amido Winter 2015 的会员
CPSU-AMIDO-W15S8G40
5 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 11
总计 2,789
