跳转到主内容
Microsoft Surface Pro 7 Screen Adhesive Replacement
你所需要的
  1. Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: 步骤 1 中的图像 1,3 Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: 步骤 1 中的图像 2,3 Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: 步骤 1 中的图像 3,3
    • Scrape away all traces of adhesive and debris from the Surface's case and screen.
    • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
    • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
  2. Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: 步骤 2 中的图像 1,2 Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: 步骤 2 中的图像 2,2
    • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
    • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
    • Once aligned, use your fingers to press the adhesive strip down against the case.
    • Repeat this procedure for the remaining three adhesive strips.
  3. Microsoft Surface Pro 7 Screen Adhesive Replacement, Install the display: 步骤 3 中的图像 1,1
    • Continue reassembly until the cables are reconnected and you're ready to install the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Remove the clear backing from the adhesive strips.
    • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
结论
3等其他人完成本指南。
Sam Omiotek
于02/25/19注册
74,453 声望
创作了288篇指南
2条评论
Pictures of the original adhesive configuration would be helpful.
HuntTheHunters - 回复
where can i buy the adshevies for surface pro 8 please
Joyce Woodhead - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 28
过去 30 天: 154
总计 4,472
