跳转到主内容
Medtronic 670G Battery Replacement
你所需要的
  1. Medtronic 670G Battery Replacement, Battery: 步骤 1 中的图像 1,2 Medtronic 670G Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Detach the clip on the back of the device.
  2. Medtronic 670G Battery Replacement: 步骤 2 中的图像 1,3 Medtronic 670G Battery Replacement: 步骤 2 中的图像 2,3 Medtronic 670G Battery Replacement: 步骤 2 中的图像 3,3
    • Place the small protrusion on the bottom of the clip into the slot on top of the battery housing, and turn it counter clockwise.
  3. Medtronic 670G Battery Replacement: 步骤 3 中的图像 1,3 Medtronic 670G Battery Replacement: 步骤 3 中的图像 2,3 Medtronic 670G Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the battery cap.
    • Dispose of the old battery according to your state guidelines.
  4. Medtronic 670G Battery Replacement: 步骤 4 中的图像 1,2 Medtronic 670G Battery Replacement: 步骤 4 中的图像 2,2
    • Insert the new battery, making sure the negative end (the flat part of the battery) is facing down.
  5. Medtronic 670G Battery Replacement: 步骤 5 中的图像 1,3 Medtronic 670G Battery Replacement: 步骤 5 中的图像 2,3 Medtronic 670G Battery Replacement: 步骤 5 中的图像 3,3
    • Replace the battery cap tighten until it is aligned.
    • Do not over-tighten the cap as it will make it extremely difficult to unscrew next time.
  6. Medtronic 670G Battery Replacement: 步骤 6 中的图像 1,1
    • Turn on the pump and wait until the HOME screen load to make sure the battery is working.
结论
Your Medtronic 670G insulin pump is good-to-go!
2等其他人完成本指南。
2条评论
Hello,
It looks like the Medtronic 670G uses standard AA batteries. You should be able to find AA batteries at most grocery and hardware stores, or online here. We hope that helps!
Connor Bassolino -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 90
总计 1,593
