跳转到主内容
Linksys WRT54GS v2 Antenna Ports Replacement
你所需要的
  1. Linksys WRT54GS v2 Antenna Ports Replacement, Front Case: 步骤 1 中的图像 1,1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 2 中的图像 1,1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 4 中的图像 1,1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Linksys WRT54GS v2 Antenna Ports Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Slide the board unit out and up.
  6. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 6 中的图像 1,1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
  7. Linksys WRT54GS v2 Antenna Ports Replacement, Antenna Ports: 步骤 7 中的图像 1,2 Linksys WRT54GS v2 Antenna Ports Replacement, Antenna Ports: 步骤 7 中的图像 2,2
    • Turn the circuit board over and identify which solder connection you will desolder.
    • The solder connections shown in red hold the right antenna port in place. There is one more attachment for this antenna on the other side of the board.
    • The solder connections shown in blue hold the left antenna port in place. Desolder these 4 points to remove the antenna port.
  8. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 8 中的图像 1,1
    • Turn on your soldering iron and allow it to get to its highest temperature setting (minimum 600ºF).
  9. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 9 中的图像 1,1
    • Desolder the connection by following iFixit's guide to repairing soldered connections: 如何焊接和拆焊.
结论
2等其他人完成本指南。
Allian Roman
于10/12/11注册
276 声望
创作了5篇指南
团队
Cal Poly, Team 3-4, Regan Fall 2011 Cal Poly, Team 3-4, Regan Fall 2011 的会员
CPSU-REGAN-F11S3G4
4 名成员
创作了12篇指南
一条评论
Most do not have removeable antennae ports
tom - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 3,255
