跳转到主内容
How to Replace Hardwood Flooring
你所需要的
  1. How to Replace Hardwood Flooring, How to Replace Hardwood Flooring: 步骤 1 中的图像 1,1
    • Remove the hardwood, tile, or carpet flooring you are trying to replace to expose the foundation or plywood underneath. The methods will vary depending on the type of flooring that is being removed.
    • Be sure to remove extra fragments of the original flooring and clean the area of any debris.
  2. How to Replace Hardwood Flooring: 步骤 2 中的图像 1,2 How to Replace Hardwood Flooring: 步骤 2 中的图像 2,2
    • With a notched trowel, spread the GreenGrip hardwood adhesive over the foundation where you would like to lay the new flooring.
  3. How to Replace Hardwood Flooring: 步骤 3 中的图像 1,2 How to Replace Hardwood Flooring: 步骤 3 中的图像 2,2
    • Measure the planks of wood to organize them into a desired pattern, then cut each plank accordingly.
  4. How to Replace Hardwood Flooring: 步骤 4 中的图像 1,1
    • Carefully place the boards on top of the glue, making sure to push the seams of the planks together.
  5. How to Replace Hardwood Flooring: 步骤 5 中的图像 1,1
    • Some of the adhesive may come through the seams, so wipe off any excess glue with a wet rag.
  6. How to Replace Hardwood Flooring: 步骤 6 中的图像 1,1
    • Let the glue cure for 24 hours and enjoy your beautiful new floor!
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 41
总计 849
