跳转到主内容
How to Open the SteelSeries Stratus Duo
你所需要的
  1. How to Open the SteelSeries Stratus Duo, Remove the sticker: 步骤 1 中的图像 1,2 How to Open the SteelSeries Stratus Duo, Remove the sticker: 步骤 1 中的图像 2,2
    • Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
    • If you have trouble removing the sticker, heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath. You can also use a hair dryer to soften the adhesive.
  2. How to Open the SteelSeries Stratus Duo, Unscrew the back cover: 步骤 2 中的图像 1,1
    • Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
  3. How to Open the SteelSeries Stratus Duo, Reposition the back cover assembly: 步骤 3 中的图像 1,3 How to Open the SteelSeries Stratus Duo, Reposition the back cover assembly: 步骤 3 中的图像 2,3 How to Open the SteelSeries Stratus Duo, Reposition the back cover assembly: 步骤 3 中的图像 3,3
    • Don't try to remove the back cover assembly all the way yet, as it's still connected to the mainboard.
    • Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
  4. How to Open the SteelSeries Stratus Duo, Disconnect the interconnect cable: 步骤 4 中的图像 1,3 How to Open the SteelSeries Stratus Duo, Disconnect the interconnect cable: 步骤 4 中的图像 2,3 How to Open the SteelSeries Stratus Duo, Disconnect the interconnect cable: 步骤 4 中的图像 3,3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
  5. How to Open the SteelSeries Stratus Duo: 步骤 5 中的图像 1,2 How to Open the SteelSeries Stratus Duo: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of blunt nosed tweezers or your fingers to pull the cable out of the socket.
  6. How to Open the SteelSeries Stratus Duo, Disconnect the battery cable: 步骤 6 中的图像 1,3 How to Open the SteelSeries Stratus Duo, Disconnect the battery cable: 步骤 6 中的图像 2,3 How to Open the SteelSeries Stratus Duo, Disconnect the battery cable: 步骤 6 中的图像 3,3
    • Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
  7. How to Open the SteelSeries Stratus Duo, Remove the back cover assembly: 步骤 7 中的图像 1,1
    • Remove the back cover assembly.
结论
4等其他人完成本指南。
Adriana Zwink
于12/18/19注册
48,810 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,439篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 74
总计 1,753
