跳转到主内容
TiVo Series 2 TCD24008A Power Supply Replacement
你所需要的
  1. TiVo Series 2 TCD24008A Power Supply Replacement, Cover: 步骤 1 中的图像 1,1
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Power Supply Replacement: 步骤 2 中的图像 1,1
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Power Supply Replacement: 步骤 3 中的图像 1,1
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Power Supply Replacement, Power Supply: 步骤 4 中的图像 1,1
    • Locate the power supply.
  5. TiVo Series 2 TCD24008A Power Supply Replacement: 步骤 5 中的图像 1,1
    • Remove the belt connecting the power supply to the motherboard by pulling it out.
  6. TiVo Series 2 TCD24008A Power Supply Replacement: 步骤 6 中的图像 1,1
    • Remove the red, yellow, and black cable connecting the power supply to the hard drive.
  7. TiVo Series 2 TCD24008A Power Supply Replacement: 步骤 7 中的图像 1,1
    • Remove the two 0.31 inch T-9 screws from the power supply.
  8. TiVo Series 2 TCD24008A Power Supply Replacement: 步骤 8 中的图像 1,2 TiVo Series 2 TCD24008A Power Supply Replacement: 步骤 8 中的图像 2,2
    • Pinch the plastic plugs and lift the power supply up to detach from plugs.
    • All 4 plugs must be detached to remove power supply.
结论
Phil Jones
于10/11/11注册
41 声望
撰写一个指南
团队
Cal Poly, Team 5-33, Amido Fall 2011 Cal Poly, Team 5-33, Amido Fall 2011 的会员
CPSU-AMIDO-F11S5G33
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,211
