跳转到主内容
How to Install an M.2 SSD
你所需要的
  1. How to Install an M.2 SSD, Reposition the standoff: 步骤 1 中的图像 1,2 How to Install an M.2 SSD, Reposition the standoff: 步骤 1 中的图像 2,2
    • If your laptop did not include a removable standoff or only supports one M.2 SSD form factor, you can skip this step.
    • Use a screwdriver to remove the preinstalled standoff.
    • If your laptop does not include a preinstalled standoff, you will need to get one.
    • Find the correct standoff location that corresponds to your desired M.2 SSD form factor.
    • Screw in the standoff.
  2. How to Install an M.2 SSD, Insert the SSD: 步骤 2 中的图像 1,3 How to Install an M.2 SSD, Insert the SSD: 步骤 2 中的图像 2,3 How to Install an M.2 SSD, Insert the SSD: 步骤 2 中的图像 3,3
    • Grip the SSD on the sides near the screw indent.
    • Gently slide the SSD into the socket at about a 30˚ angle.
    • The socket is spring loaded and will support the SSD at an angle.
  3. How to Install an M.2 SSD, Screw down the SSD: 步骤 3 中的图像 1,3 How to Install an M.2 SSD, Screw down the SSD: 步骤 3 中的图像 2,3 How to Install an M.2 SSD, Screw down the SSD: 步骤 3 中的图像 3,3
    • Use your finger to hold the SSD down horizontally, making sure that the screw indent aligns with the standoff.
    • Screw down the SSD to secure it.
  4. How to Install an M.2 SSD, Apply a thermal pad: 步骤 4 中的图像 1,3 How to Install an M.2 SSD, Apply a thermal pad: 步骤 4 中的图像 2,3 How to Install an M.2 SSD, Apply a thermal pad: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • If your laptop did not have a thermal pad installed, you can skip this step.
    • Use tweezers or your fingers to place a thermal pad on the top of the SSD.
    • The original thermal pad can be reused if it is clean and undamaged.
结论
Installation didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
6等其他人完成本指南。
Chayton Ritter
于08/21/20注册
18,791 声望
创作了102篇指南
团队
Guide Team Guide Team 的会员
Staff
7 名成员
创作了7,907篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 67
过去 30 天: 252
总计 4,147
