跳转到主内容
Datawind Ubislate 7ci Rear Facing Camera Replacement
你所需要的
  1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Finding a work space: 步骤 1 中的图像 1,1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: 步骤 2 中的图像 1,2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: 步骤 2 中的图像 2,2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves.)
  3. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: 步骤 3 中的图像 1,2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: 步骤 3 中的图像 2,2
    • Remove the black tape that is circled.
    • The camera is circled in this picture.
  4. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: 步骤 4 中的图像 1,2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: 步骤 4 中的图像 2,2
    • Carefully remove the camera from its housing.
  5. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: 步骤 5 中的图像 1,2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: 步骤 5 中的图像 2,2
    • Slide the new camera into its housing carefully.
    • it should look like the second picture when you are finished
  6. Datawind Ubislate 7ci Rear Facing Camera Replacement, Closing the Tablet: 步骤 6 中的图像 1,1
    • Press the back cover of the tablet on firmly until it clicks
结论
2等其他人完成本指南。
Mekides
于10/20/14注册
40 声望
创作了3篇指南
团队
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G3
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 293
