跳转到主内容
Datawind Ubislate 7ci Battery Replacement
你所需要的
  1. Datawind Ubislate 7ci Battery Replacement, Battery: 步骤 1 中的图像 1,2 Datawind Ubislate 7ci Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • Be careful of the device's small wiring when separating the two halves.
  2. Datawind Ubislate 7ci Battery Replacement: 步骤 2 中的图像 1,3 Datawind Ubislate 7ci Battery Replacement: 步骤 2 中的图像 2,3 Datawind Ubislate 7ci Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the black tape.
    • Be careful not to remove the tablet camera.
  3. Datawind Ubislate 7ci Battery Replacement: 步骤 3 中的图像 1,3 Datawind Ubislate 7ci Battery Replacement: 步骤 3 中的图像 2,3 Datawind Ubislate 7ci Battery Replacement: 步骤 3 中的图像 3,3
    • Use a soldering iron to remove the battery from both its attachment points.
    • Pry off the battery using an opening tool.
  4. Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: 步骤 4 中的图像 1,2 Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: 步骤 4 中的图像 2,2
    • Insert your replacement battery in the same spot as the old battery.
    • Tape battery into place.
  5. Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: 步骤 5 中的图像 1,2 Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: 步骤 5 中的图像 2,2
    • Solder the new battery to the connection points.
    • Press the back cover on firmly until it clicks.
结论
6等其他人完成本指南。
Mekides
于10/20/14注册
40 声望
创作了3篇指南
团队
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G3
3 名成员
创作了6篇指南
2条评论
On my 7Ci the battery is SFH-HLKJ-204.
Datawind doesn't sale those pieces.
Where can I find one?
What type is it, voltage and so?
THX!
ylco - 回复
3.7V, 2200mAh lithium ion. Yiu can get a bigger or smaller one depending on shat you want.
Jessica Parnelli Fawkes - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 16
总计 9,034
