跳转到主内容
三星Galaxy S10+ 更换 SIM/MicroSD 卡
你所需要的
  1. 三星Galaxy S10+ 更换 SIM/MicroSD 卡, SIM/MicroSD 卡: 步骤 1 中的图像 1,3 三星Galaxy S10+ 更换 SIM/MicroSD 卡, SIM/MicroSD 卡: 步骤 1 中的图像 2,3 三星Galaxy S10+ 更换 SIM/MicroSD 卡, SIM/MicroSD 卡: 步骤 1 中的图像 3,3
    • 将SIM卡弹出工具,螺丝刀替换头或拉直的回形针插入SIM托盘上的孔中,该托盘位于塑料天线带旁边的手机顶部边缘。
    • 如果你将工具插入手机顶部边缘的另一个孔中,也不要担心——麦克风外面装了一个线圈,不会把它不小心戳坏的。
    • 用力按压以弹出托盘。
    • 取出SIM卡托盘。
    • 重新插入SIM卡时,请确保其相对于托盘处于正确的方向。
结论
要重新组装你的设备,请按照这些说明以相反的顺序进行。
在你完成维修后, 按照这个指南 测试你的修理成果.
4等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Arthur Shi
于01/03/18注册
256,403 声望
创作了529篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了17,681篇指南
5条评论
I have the same question. I'm sure you've taken enough of these apart for repair. (Galaxy s10's and pluses) Can you guys see what's at the end of the hole? Any research that I've found says that the hole is straight and comes to an end and the microphone is 90° to that, so it cannot be poked by the pin, is this true? (I hope it is, and to give us peace of mind!) I don't want to have to take apart my phone. I'm sure there are lots people out here that have poked this %#*@ hole and are freaking that we have wrecked a $1600.00 phone! And then, if you could kindly please then post an answer plainly in the instructions for the SIM installation somewhere in the body of this installation article. I have seen no definitive answer to this mistake in any other article that I've read. Ifixit is the premiere repair company for phones, this should be solved here. Thanks in advance I hope. I've used your services multiple times in the past for various breakages of our family phones in Chicago, you've always been great.
Lin Car - 回复
Hi Lin,
Please look for the answer in step 1’s comments.
Arthur Shi -
I inserted the pin in the microphone hole first. Thank you for setting my mind at ease that I didn’t damage anything,
Craig Thielke - 回复
Where can you order a OEM SM-G975U Prism Blue sim card tray from? I want a genuine Samsung replacement.
MarkC 609 - 回复
well we have a dilemma here my s10+ ihas got a micro sim card stuck in the sd slot see if you can get it out by taking the phone apartand also ill need directions to you
Kevin Gaiser - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 43
过去 30 天: 156
总计 14,419
